IceracerX Posted July 26, 2017 Report Share Posted July 26, 2017 I picked up a set of Keihin pwk 28mm carbs for a good price locally. I did some searching can't seem to find what the float height should be set at. One post said 16mm to the line on the float, other one said 19mm only( I would assume to top of the float). No real help on Keihin's sight either. Quote Link to comment Share on other sites More sharing options...
IceracerX Posted July 26, 2017 Author Report Share Posted July 26, 2017 Mine are 16mm right to the Top Line that is 18 mm to the top of the floatSent from my XT1526 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 26, 2017 Report Share Posted July 26, 2017 http://www.carbparts.com/keihin/needles_tuning/jetting_your_carb.htm Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted July 26, 2017 Report Share Posted July 26, 2017 35 to 39mm carbs are 16mm pretty sure 28s are 19mm Just put some gas line on the gas nozzle tube part and hold the carb in your hand, blow into the line, push the float up until it stops the air, it should stop when the float is parallel with the carb body or just a TAD before. That's how ive always done it along with others as well and its works fine. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted July 26, 2017 Report Share Posted July 26, 2017 Also remember that keihin carbs need to be tilted on an angle to properly check height so the pin spring doesn't give you a false measurement Quote Link to comment Share on other sites More sharing options...
IceracerX Posted July 26, 2017 Author Report Share Posted July 26, 2017 Thanks.Sent from my XT1526 using Tapatalk Quote Link to comment Share on other sites More sharing options...
