Banshee modification help??
Ok so i have a 1997 yamaha banshee and im looking to make a bad bitch of it. So I plan on doing 20cc domes, 34mm carb, advanced timing, dyna cdi, full fmf powercore 2 exhaust. So what I am wondering is with all this should i run 110 octane? also do i have to program the dyna before i put it on and go riding? and what are the specs for the air/ idle adjustment on the 34mm carbs for 70 degree weather?
20cc domes will get you more compression and probably make a torquier motor. You'll need to run a high enough octane fuel to prevent deto.
What kind of carbs? Keihin makes a 34 pj. I don't care for pj carbs. I prefer PWK carbs but to each his own.
I think the Dyna has preset curves that you can select whenever you want.
thank you. do you know how many turns out the air and screw needs?
With higher compression 20cc domes and timing, definitely bank on running 110.  In all honesty, you don't need a Dyna CDI, as results will be marginal. The good ol fashioned timing plate is the most reliable way to advance the timing. CDI is hundreds, and the timing plate is about $50. If you insist on trying the CDI, make sure your timing plate is at zero or the Dyna is programmed to compensate whatever you have on the plate. Also, with setting a motor up for race gas, you need to consider making sure the crank is true and get the pins welded. Also put a couple new Max Load bearings on the out side ends.  As far as 34mm carbs, the PJ's are cheap and can be made to run ok, but a set of PWK's from Keihin would run better. My concern is that you are looking at carbs that may be a bit to big for the set up you are going for. With out doing port work and a stroker crank, you should be looking at 28mm or 33mm PWK's. 28's if you're running trails and need more bottom end. 33's if you are in more wide open terrain.
2 minutes ago, ZillaFreak said:
110 is way to much octane for 20cc and the basic +4 timing.
Correct, it's really on tipping point. However I get the feeling he is gonna be looking to throw as much timing at as he can get.
18 minutes ago, ZillaFreak said:
I have a feeling in a month, he will post about rebuilding the engine.
jokes on you i already rebuilt it lol but thats only cuz the guy i bought it from didnt know how to run the damn thing. I appreciate al the help. I am still learning about the higher performance work and how to make everything run good and right with domes, pipes, carbs...
18 minutes ago, trickedcarbine said:
I just envision the timing plate being set at + 4 and the Dyna getting set to an advanced curve. That's a fuck ton of timing for a motor to see on just pump.
But if it gets set up right, it'll be fine on fresh premium.
the only reason im looking into  new cdi is because my oem is fried. ill have the cdi set at oem power curve but what is the best set up for me to get good performance but having a reliable build?
OEM ignition components, with an adjustable timing plate.
