STRIBZ Posted July 21, 2017 Report Share Posted July 21, 2017 Need help making up my mind on pipes! Mods are: 421 lp driveline cylinders "as cast" 95% duning 5% trails 15/41 gearing I like popping wheelies and play dragging. so like top end with some bottom-mid. what pipes you think will suit me and why?? AND GO!!!! Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 21, 2017 Report Share Posted July 21, 2017 Need help making up my mind on pipes! Mods are: 421 lp driveline cylinders "as cast" 95% duning 5% trails 15/41 gearing I like popping wheelies and play dragging. so like top end with some bottom-mid. what pipes you think will suit me and why?? AND GO!!!!Probably gonna be Shearer or snipers. CPIs would contend here also. Shearers on my 4m dune port. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 21, 2017 Report Share Posted July 21, 2017 That's a first gear launch and you can see the roost shift to second. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted July 21, 2017 Author Report Share Posted July 21, 2017 Nice mate!, i thought shearer came on real late and revved out longer? thought shearers and CPI liked a bigger ex port? Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 21, 2017 Report Share Posted July 21, 2017 I ran both on my dune ported motor. It is an aggressive dune port geared more towards a high rpm motor but that's what it sounded like you wanted. But you can ask many on here how that motor runs for a duner in the trails and across the open dunes. I wouldn't change anything with it and likely couldn't build another like it. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted July 21, 2017 Author Report Share Posted July 21, 2017 I've been tossing up between SLP and CPi. put it this way anything will be an improvement as i'm currently running raped out fmf fatty's Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 21, 2017 Report Share Posted July 21, 2017 I've been tossing up between SLP and CPi. put it this way anything will be an improvement as i'm currently running raped out fmf fatty'sLove my shearers over CPIs but would welcome the opportunity to try snipers. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted July 21, 2017 Author Report Share Posted July 21, 2017 cheers Spurdy ill look into shearers as well. Oh and sick BBQ skills! 1 Quote Link to comment Share on other sites More sharing options...
rubberneck Posted July 21, 2017 Report Share Posted July 21, 2017 I prefer my cpi over my shearers but have never tried snipers. If i was only racing i probably would have stuck with the shearer. They pull harder at the top but i felt the cpi were a much better all around pipe. The cpi were way better if you had to get out of the throttle and then get back in it. With the shearers it seemed llike once you come off the power you are clutching or down shifting to get anything back. I ran them on a 421 cub and 2 different 4 mill dune ported motors Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted July 21, 2017 Author Report Share Posted July 21, 2017 thanks for the reply, Yes thats what i have read about shearers vs CPI. How you think CPI would run on smaller ex port?? 191/121 Quote Link to comment Share on other sites More sharing options...
rubberneck Posted July 21, 2017 Report Share Posted July 21, 2017 32 minutes ago, STRIBZ said: thanks for the reply, Yes thats what i have read about shearers vs CPI. How you think CPI would run on smaller ex port?? 191/121 I cant answer as ive never tried. i believe my dune port motor was 195/130. I checked but its been about 7 years and im not positive. i do have a serval top end sitting around i had planned on throwing on but just never have and at this point most likely never will. Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted July 21, 2017 Author Report Share Posted July 21, 2017 No worries, thanks anyway. may slap on some SLP pipes and gear for them, either stick with the 15 or maybe 16 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted July 21, 2017 Report Share Posted July 21, 2017 Green is SLPRed is ShearerBlue is Sniper On a LP, cleaned port, 35mm, +5 or +6 I think SLP won. 1 Quote Link to comment Share on other sites More sharing options...
ginger Posted July 21, 2017 Report Share Posted July 21, 2017 slp run really well, but the power comes in a lot lower in the RPM range and falls off faster. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted July 21, 2017 Report Share Posted July 21, 2017 slp run really well, but the power comes in a lot lower in the RPM range and falls off faster.I think they are the best for that setup for everything but drag.Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
