2strokedev Posted July 13, 2017 Report Posted July 13, 2017 So i just rebuilt my bike top end because compression got down to 85psi now that im back up to 125 in both cylinders. The bike is completely stock besides it has 2 k&n pod filters . It has stock carbs with the tors delete. Im running in lower michigan where the elevation is about 600ft above sea level. What jets should i have in the bike . Im running a 32:1 mixture with klotz r50. Any help would be awesome thanks in advance Quote
Ayesully810 Posted July 13, 2017 Report Posted July 13, 2017 What pipes do you have? stock or after market? so it has two pods kns off the carbs? If so 27.5 pilot should be good with a 290 main. what are your jetting specs right now? Quote
