martin059 Posted July 10, 2017 Report Posted July 10, 2017 Sorry for the noob question but what's the best kind of transmission oil to use and how often should I change the oil. Also what about break oil? Sent from my iPhone using Tapatalk Quote
spurdy Posted July 10, 2017 Report Posted July 10, 2017 Sorry for the noob question but what's the best kind of transmission oil to use and how often should I change the oil. Also what about break oil? Sent from my iPhone using TapatalkI use 10w40 oil approved for wet clutch applications. Trans oil breaks down too quickly and requires constant changing. Castrol actevo 4T is what I use. Brake fluid, DOT 3 DOT 4. Not sure it makes a difference. Sent from my iPhone using Tapatalk Quote
martin059 Posted July 10, 2017 Author Report Posted July 10, 2017 Right on thanks for the info Sent from my iPhone using Tapatalk Quote
ginger Posted July 11, 2017 Report Posted July 11, 2017 I used either maxima 80-90w wet clutch trans fluid or scheaffers equivalent since I have a 5 gallon bucket of it Quote
SandSlingerOR Posted July 11, 2017 Report Posted July 11, 2017 Mobil 1 10w40 works great. I was skeptical but it actually is good stuff. Shifting is smooth.. Quote
martin059 Posted July 12, 2017 Author Report Posted July 12, 2017 Thanks for all the help guys Sent from my iPhone using Tapatalk Quote
hotrodbanshee Posted July 12, 2017 Report Posted July 12, 2017 On 7/11/2017 at 1:23 AM, SandSlingerOR said: Mobil 1 10w40 works great. I was skeptical but it actually is good stuff. Shifting is smooth.. Think I'll give dat a try when I get my new motor put back together Quote
ClaudeMachining Posted July 12, 2017 Report Posted July 12, 2017 I use gear oilNo shit! Gear oil with a geared tranny! ;-)Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote
JTmachining Posted July 12, 2017 Report Posted July 12, 2017 No shit! Gear oil with a geared tranny! ;-)Envoyé de mon SM-G935W8 en utilisant TapatalkNot everyone uses gear oil Claudia Quote
ClaudeMachining Posted July 12, 2017 Report Posted July 12, 2017 Not everyone uses gear oil ClaudiaI know, thus my comment :-)Envoyé de mon GT-P5113 en utilisant Tapatalk 1 Quote
