cmoore14 Posted July 4, 2017 Report Share Posted July 4, 2017 Riding and back tires locked when I shifted to 2nd now won't move when I star it and put it in 1st gear Quote Link to comment Share on other sites More sharing options...
ginger Posted July 5, 2017 Report Share Posted July 5, 2017 A little more information would do you wonders Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 5, 2017 Report Share Posted July 5, 2017 pull the clutch cover first. If there isn't any obvious culprit, you'll be splitting the cases. Quote Link to comment Share on other sites More sharing options...
blowit Posted July 5, 2017 Report Share Posted July 5, 2017 Sounds like a gear welded itself to a transmission axle. Can't remember right off but thinking it was 2nd that was known for this and the newer OEM gear now has a better bushing in it. We dealt with several over the years. Basically a gear that should spin free on a trans shaft welds itself on. Indications would be to remove the drive chain, then pull clutch lever and start bike. If engine will run but even slightly bogs engine when you try to engage clutch, the trans has issues. Brandon Mull Engineering 1 Quote Link to comment Share on other sites More sharing options...
