arena314 Posted July 3, 2017 Report Share Posted July 3, 2017 hi so I installed idle screws on my banshee and have t5 pipes and a uni filter with no lid that's it. I'm running 27.5 pilots and 270 mains. I'm having an issue where it'll idle hreat but when I ride it and get on it the idle will go up a lot and the throttle feels like it's sticking almost. this started happening when installing the idle screws. any suggestions? thanks Sent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 3, 2017 Report Share Posted July 3, 2017 Are you referring to an idle screw kit like what comes with the TORS delete? Where are the air screws set at? It should idle back down when screwing them in. If that doesn't make much difference, you need to check for air leaks. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 3, 2017 Report Share Posted July 3, 2017 might have gotten the screws in a little crooked and they are dragging on the side of the ramp. It would only stick until maybe 1/4 throttle, if that much. (until the screws clear the slide) Quote Link to comment Share on other sites More sharing options...
arena314 Posted July 3, 2017 Author Report Share Posted July 3, 2017 it's done this to me twice and both times are after the bike got wet I'm starting to think the issue is if a little water gets in the slides it causes the throttle to stickSent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 3, 2017 Report Share Posted July 3, 2017 Yes, common knowledge... those carbs hate water. Quote Link to comment Share on other sites More sharing options...
arena314 Posted July 4, 2017 Author Report Share Posted July 4, 2017 yeah I've been running no lid I'm going to put the lid back on and try to keep them as dry as possibkeSent from my SM-G935T using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 4, 2017 Report Share Posted July 4, 2017 I run an EHS Racing lid prefilter on mine, Same jetting as no lid but makes it water repellent. Quote Link to comment Share on other sites More sharing options...
arena314 Posted July 6, 2017 Author Report Share Posted July 6, 2017 how much would running a stock lid change my jetting?Sent from my SM-G935T using Tapatalk Quote Link to comment Share on other sites More sharing options...
