Jahman Posted July 2, 2017 Report Share Posted July 2, 2017 I have a banshee has 3hrs on top and bottom end was running fucking crispy rode it today was fine started it up a little later it started backfiring changed the plugs for some reason made it worse only firing 1 cylinder now Please help need it fixed befor the 4th of july thanks... Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 2, 2017 Report Share Posted July 2, 2017 Check the flywheel key. Maybe even reeds. Quote Link to comment Share on other sites More sharing options...
Jahman Posted July 2, 2017 Author Report Share Posted July 2, 2017 6 hours ago, hoppedupandcutdown said: Check the flywheel key. Maybe even reeds. Thanks will check a little later Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted July 2, 2017 Report Share Posted July 2, 2017 Could have developed an air leak. Pressure test before you tear your hair out 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 2, 2017 Report Share Posted July 2, 2017 You mentioned spark plugs made a negative difference. Were they solid tip or thread on tip? Quote Link to comment Share on other sites More sharing options...
registered user Posted July 2, 2017 Report Share Posted July 2, 2017 flywheel key would affect both cylinders. check it if you want but I don't believe its your problem with backfiring and a dead cylinder I would probly first look at cdi and coil. if your using any Chinese ign parts I would suspect those very first thing Quote Link to comment Share on other sites More sharing options...
Jahman Posted July 2, 2017 Author Report Share Posted July 2, 2017 4 hours ago, registered user said: flywheel key would affect both cylinders. check it if you want but I don't believe its your problem with backfiring and a dead cylinder I would probly first look at cdi and coil. if your using any Chinese ign parts I would suspect those very first thing All stock i really dont think its electrical unless the key is fucked Quote Link to comment Share on other sites More sharing options...
Jahman Posted July 2, 2017 Author Report Share Posted July 2, 2017 6 hours ago, trickedcarbine said: You mentioned spark plugs made a negative difference. Were they solid tip or thread on tip? Yes there thread with caps off Quote Link to comment Share on other sites More sharing options...
Jahman Posted July 2, 2017 Author Report Share Posted July 2, 2017 6 hours ago, trickedcarbine said: You mentioned spark plugs made a negative difference. Were they solid tip or thread on tip? Same spark plugs i used since build Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 2, 2017 Report Share Posted July 2, 2017 Have you got to put a compression gauge on it to make sure it's not fried in one cylinder? Checked for air leaks? Quote Link to comment Share on other sites More sharing options...
registered user Posted July 3, 2017 Report Share Posted July 3, 2017 it doesnt sound like you spent one moment in the garage to figure it out or itb fixed by now Quote Link to comment Share on other sites More sharing options...
