Banshee 400 Posted July 1, 2017 Report Share Posted July 1, 2017 Banshee is smoking a ton on one side not much on the other both cylinders are running compression is good but why is is smoking more on the right? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 1, 2017 Report Share Posted July 1, 2017 Banshee is smoking a ton on one side not much on the other both cylinders are running compression is good but why is is smoking more on the right? Sent from my iPhone using TapatalkCould be sucking in oil through the crank seal on the clutch side. Assuming that is what you mean by right side. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted July 2, 2017 Report Share Posted July 2, 2017 Same thing happened to me on my old motor. Ended up being the rings in the bad cylinder on the exhaust side the ring was getting hung up.. Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 2, 2017 Report Share Posted July 2, 2017 Same thing happened to me on my old motor. Ended up being the rings in the bad cylinder on the exhaust side the ring was getting hung up..How is that going to make it smoke excessively? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted July 2, 2017 Report Share Posted July 2, 2017 Don't know bro, but the mechanic that rebuilt it told me that was the culprit.. Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 2, 2017 Report Share Posted July 2, 2017 Don't know bro, but the mechanic that rebuilt it told me that was the culprit.. Makes no sense. Failed rings cause low compression. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted July 2, 2017 Report Share Posted July 2, 2017 https://atvconnection.com/forums/yamaha/36002-1-pipe-smoking-than-other-banshee.html http://www.fixya.com/motorcycles/t17798770-banshee_one_pipe_smoking_other_not_fix https://atvconnection.com/forums/yamaha/59739-banshee-smoking-right-side-only-please-help.html Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 2, 2017 Report Share Posted July 2, 2017 https://atvconnection.com/forums/yamaha/36002-1-pipe-smoking-than-other-banshee.htmlhttp://www.fixya.com/motorcycles/t17798770-banshee_one_pipe_smoking_other_not_fixhttps://atvconnection.com/forums/yamaha/59739-banshee-smoking-right-side-only-please-help.html ^^^this. Oil is what makes it smoke. Since your fuel charge first goes into the crankcase before traveling through the transfers into the combustion chamber a worn out set of rings allowing blowby isn't going to make it smoke anymore than usual since your fuel charge in the crankcase has the same oil in it as the fuel charge sent through the transfers into the combustion chamber. THIS IS NOT A 4 STROKE. Oil leaking through a worn or damaged seal on the right side of the clutch cover will add oil to the right side of the crankcase and send it with the fuel charge to the combustion chamber, burning this excess oil with the fuel charge producing smoke. That's a logical cause as opposed to repeating something you've heard somebody else claim but have no way of explaining it. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 2, 2017 Report Share Posted July 2, 2017 I agree with Spurdy on all of the above. Quote Link to comment Share on other sites More sharing options...
tmace Posted July 3, 2017 Report Share Posted July 3, 2017 Is it smoke or steam? It could also be as simple as a bad o ring on one side. Quote Link to comment Share on other sites More sharing options...
Banshee 400 Posted July 3, 2017 Author Report Share Posted July 3, 2017 Is it smoke or steam? It could also be as simple as a bad o ring on one side.I believe it's smoke...Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
tmace Posted July 3, 2017 Report Share Posted July 3, 2017 If you're still full of coolant that would also rule out a bad o ring. Quote Link to comment Share on other sites More sharing options...
Banshee 400 Posted July 3, 2017 Author Report Share Posted July 3, 2017 If you're still full of coolant that would also rule out a bad o ring.I'll give that a check didn't really think about it being a o ring, thanks! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 3, 2017 Report Share Posted July 3, 2017 If it is steam, this could be the case. But smoke is oil. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 3, 2017 Report Share Posted July 3, 2017 I'll give that a check didn't really think about it being a o ring, thanks! Sent from my iPhone using TapatalkCheck your coolant level. If it is coolant your level will obviously drop. You can also smell the difference between coolant and oil. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
