Ayesully810 Posted June 27, 2017 Report Share Posted June 27, 2017 Yeah i thought shearers too. Well u can tell by looking at the cylinders if they have been ported or not but u should probably just post pictures on here. You know if u have a cool head if its shiny haha i guess thats best way i can explain it for you. Reeds- if they are v force reeds it will say on the sides of the cages. If compression is 180 then you have a cool head or a stock head thats been modified. If u have a different crank than stock they are stamped on the side of the rods with a model number Quote Link to comment Share on other sites More sharing options...
kawa110 Posted June 27, 2017 Report Share Posted June 27, 2017 8 more bolts...Buy a base gasket and cool head o rings.Measure cylinders---take them someplace that can measure them and fit them with new pistons/rings. Make your self a leak down tester... Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 27, 2017 Report Share Posted June 27, 2017 8 more bolts...Buy a base gasket and cool head o rings.Measure cylinders---take them someplace that can measure them and fit them with new pistons/rings. Make your self a leak down tester... Omg, you're gonna confuse this cat beyond. Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 27, 2017 Author Report Share Posted June 27, 2017 7 minutes ago, spurdy said: So do you have CPIs or Shearer pipes? Sent from my iPhone using Tapatalk I have cpis. I thought shearers was what you called the part of the exhaust that's by your legs... lol my mad https://ibb.co/guFD7k Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 27, 2017 Author Report Share Posted June 27, 2017 7 minutes ago, Ayesully810 said: Yeah i thought shearers too. Well u can tell by looking at the cylinders if they have been ported or not but u should probably just post pictures on here. You know if u have a cool head if its shiny haha i guess thats best way i can explain it for you. Reeds- if they are v force reeds it will say on the sides of the cages. If compression is 180 then you have a cool head or a stock head thats been modified. If u have a different crank than stock they are stamped on the side of the rods with a model number I do have a cool head sorry forgot to mention. I'm on stock cages for sure but the inside was carbon fiber so my buddy thought they might not be stock. Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 27, 2017 Report Share Posted June 27, 2017 I do have a cool head sorry forgot to mention. I'm on stock cages for sure but the inside was carbon fiber so my buddy thought they might not be stock.Carbon fiber reeds are not stock. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted June 27, 2017 Report Share Posted June 27, 2017 1 minute ago, spurdy said: Omg, you're gonna confuse this cat beyond. Sent from my iPhone using Tapatalk You beat me to it. Thats just gunna go over his head Op if u really wanna learn how to work on these, read in these forums as much as you can and use that search bar to type in key words of what ur looking for. Ive been on here actively for a year now almost and ive learned a lot and am still learning, most ppl here are willing to help too. Learning to diagnose a problem is important that way ur not chasing ur tail 2 Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 27, 2017 Report Share Posted June 27, 2017 At this point you're probably best off to just post pics of everything. No offense, but I can't trust anything without a photo. Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 27, 2017 Author Report Share Posted June 27, 2017 5 minutes ago, kawa110 said: 8 more bolts... Buy a base gasket and cool head o rings. Measure cylinders---take them someplace that can measure them and fit them with new pistons/rings. Make your self a leak down tester... Gonna look into the leakdown test after I get everything back together. I was thinking about ordering some new piston and swapping them myself, or do you guys not reccomend that? I want to save $$ obviously by avoiding the mechanic route, but I want to do things right. Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 27, 2017 Author Report Share Posted June 27, 2017 1 minute ago, spurdy said: At this point you're probably best off to just post pics of everything. No offense, but I can't trust anything without a photo. Sent from my iPhone using Tapatalk Not a problem, I can post pics of everything's you guys need me to, just ask. It helps me too that way we're on the same page. What should my next step here be? Remove my cylinders? Should I place an order for a new set of reeds? If so which ones? Is it possible for me to get this done without going to a shop or mech? Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 27, 2017 Report Share Posted June 27, 2017 Gonna look into the leakdown test after I get everything back together. I was thinking about ordering some new piston and swapping them myself, or do you guys not reccomend that? I want to save $$ obviously by avoiding the mechanic route, but I want to do things right.You have 65.50mm pistons. Stock is 64mm. So your cylinders have been bored over stock. Not good or bad just where you're at in the usable life of the cylinder sleeve. I wouldn't bore bigger than 66mm but that's me. Weisco makes larger dia pistons than 66mm. That being said, before I put a set of pistons in it is want to make sure my bore was good. You need a bore gauge for that. A tapered bore or egg shaped bore will lead to failure. Your cylinder walls need to be parallel all the way around. A clymers manual has photos of how to check this with a bore gauge. All of this information is out there and available if you will research it. I know, asking someone is much easier, but you'll learn a lot more and remember a lot more if you work for the information a little bit. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted June 27, 2017 Report Share Posted June 27, 2017 Pistons and rings need fitted to cylinders, If you have the patience every here could walk you through most things and save you $ Post more pics..if you have a cool head the domes may be stamped with a number to tell size Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted June 27, 2017 Report Share Posted June 27, 2017 Yes its possible. First take apart your top end and post pics of everything. Pistons and what the insides of the cylinders look like Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 27, 2017 Report Share Posted June 27, 2017 Yes its possible. First take apart your top end and post pics of everything. Pistons and what the insides of the cylinders look like I am out on that one. For $40-$50 a hole I don't even mess with my own cylinders. Send them out and have them bored for the size piston I'm using. Done. Pistons today are accurate enough they don't need to be fitted. Just double checked. Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted June 27, 2017 Report Share Posted June 27, 2017 2 minutes ago, kawa110 said: Pistons and rings need fitted to cylinders, If you have the patience every here could walk you through most things and save you $ Post more pics..if you have a cool head the domes may be stamped with a number to tell size I would highly recommend getting smaller cc domes so you can run pump gas and not eff ur engine. That can be done when you go to order pistons from a builder on here Quote Link to comment Share on other sites More sharing options...
