What is this leak?
2 minutes ago, spurdy said:
I don't have anything stick to compare it to but I think stock static compression should be around 130 psi Fresh. Anything less than 80 or 90 psi is getting pretty worn.
I hear stock is 110-150 so my right side was pretty high which is a good thing right? But as for that left side? It's dead
1 minute ago, ginger said:
pretty much.
most guys are between 115-130 without any mods depending on a few other factors.
im going to say the one piston is toast.  only way to confirm it is by pulling the head.
How could this have happened? Is rebuilding something I can take on myself if it comes down to that?
Left side is too high if it really is 180. That is going to cause detonation on regular 87 octane fuel. Hell, it will even deto on 91 octane. Right side at 30psi will never fire.
Left side is too high it it really is 180. That is going to cause detonation on regular 87 octane fuel. Hell, it will even deto on 91 octane. Right side at 30psi will never fire.
Vice versa left side when sitting on the quad is the one that's low. Regardless, I always pump 93 nothing lower. What should be my next step here guys?
not looking like I'm gonna be taking the shee out this weekend huh? Fml
Edited by Rawnold
180 static compression will require nothing less than 110 octane.
next step in my mind is drain the coolant and pull off the head. see if the piston is damaged.
Damn then it's possible I kicked it too many times? I mean I kicked till the needle didn't move any further, I was hitting the throttle don't know if it matters. My left side I kicked just as many times but it wouldn't go past the 30s range
Hot damn. Sounds like I'm gonna be in for some serious mechanical shit.. I'll look up some videos and talk to my buddy to see if he can maybe give me a hand with it. I'll keep you guys posted. As always much appreciated fellas
  • Like 1
After reading through this, I would send out to motor to a reputable builder if I were you .. Not to be a dick but I would not attempt to rebuild a motor without even knowing the strokes of a motor.
Sent from my LG-H820 using Tapatalk
  • Like 1
I mean everything is a learning process imo.. if this isn't something you need serious experience for it's just kind of a swapping parts type of things I can definitely do it, especially with a forum giving me support.. but if that isn't the case and this is something that's gonna take experience let me know
if you dont know about gapping plugs or doing a compession test.  you are either going to want to just spend a ton of time just reading on here, or taking it to someone.
down in flordia there is this southern performance guy that does good work from what i can tell.
You can't kick it over too many times. Holding the throttle wide open will help reach max static compression faster.
Just didn't it again, if I'm supposed to kick till the needle stops moving what I said earlier was pretty accurate. If anything the left side is a little higher closer to 50.
About to remove head, should I remove the head or the shearer exhaust first to look at my piston before removing the head?
1 hour ago, kawa110 said:
If u have 50psi and it is accurate....
Time for rings.
Pull the exhaust and carbs so u can pressure test. Then pull the head.
Just saw this, already pulled off my head
heres some pics, the hose you see is the radiator hose so let that be your north.
https://ibb.co/bQSexk
https://ibb.co/iTH1A5
Piston does not look too damaged to me, the left side piston (one with low compression) does seem kinda grinded on the edges but not tore up. How can I check rings? Do I have to pull off cylinder as well?
