rubberneck Posted June 26, 2017 Report Share Posted June 26, 2017 Ive had terrible luck with aftermarket needle and seats. They seem to always leak. my guess is after your carb rebuild one or both of your needle/seats is leaking Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 26, 2017 Author Report Share Posted June 26, 2017 Alright guys so I took the carbs off checked my float it was a little off (when flipped upside down it sat low) so I bent the clip to raise it up a bit or lower it when it's sitting up right and I reinstalled and went to crank on but still won't fire up. Before my carb repair a few weeks back, it used to leak out of the hose connected to the carb basket (bottom part you unscrew to expose float and all that) now it's leaking off the bolt on the bottom, accidentally left my fuel on last night and there's a pretty decent size puddle under my engine, none out of the hoses. Whats going on guys, did I damage my motor is that why it isn't starting? Or is this carb related? Quote Link to comment Share on other sites More sharing options...
ginger Posted June 26, 2017 Report Share Posted June 26, 2017 it is all carb related. im sure. Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 26, 2017 Author Report Share Posted June 26, 2017 53 minutes ago, ginger said: it is all carb related. im sure. How can I address the issue then? I tried adjusting the float already what else could it be? Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted June 26, 2017 Report Share Posted June 26, 2017 Ive had terrible luck with aftermarket needle and seats. They seem to always leak. my guess is after your carb rebuild one or both of your needle/seats is leakingThis. Pull your plugs, kick the shit out of it with the fuel OFF and see if you blow a bunch of gas out the plug holesGiving away "TSS" for FREE!!! Quote Link to comment Share on other sites More sharing options...
ginger Posted June 26, 2017 Report Share Posted June 26, 2017 when you adjusted the floats and said they were low. were the low the distance from the carb to the top of the float. meaning that distance is longer or shorter now. i assume you put your choke tube back in correct? Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 26, 2017 Author Report Share Posted June 26, 2017 4 minutes ago, rjdgriff said: This. Pull your plugs, kick the shit out of it with the fuel OFF and see if you blow a bunch of gas out the plug holes Giving away "TSS" for FREE!!! Kick it with my spark plugs unscrewed to see if gas comes out those holes? What would this tell me? I will try in a sec, just making sure we're talking about the same plugs. & to ginger yes I measured from were the gasket sits (with gasket off) to the top of the float. & yeah I put the choke tune back on Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted June 26, 2017 Report Share Posted June 26, 2017 Kick it with my spark plugs unscrewed to see if gas comes out those holes? What would this tell me? I will try in a sec, just making sure we're talking about the same plugs. & to ginger yes I measured from were the gasket sits (with gasket off) to the top of the float. & yeah I put the choke tune back on Yes. If you are blowing fuel out the spark plug holes, your cases are flooded to hell and it will be a bitch to startGiving away "TSS" for FREE!!! Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 26, 2017 Author Report Share Posted June 26, 2017 1 minute ago, rjdgriff said: Yes. If you are blowing fuel out the spark plug holes, your cases are flooded to hell and it will be a bitch to start Giving away "TSS" for FREE!!! Okay, I'll get them off and try kicking it, should I expect it to crank up? Or just spew out the gas then I plug them back up and kick her with the fuel on? Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted June 26, 2017 Report Share Posted June 26, 2017 It will not start with the plugs out. Right now I'm just trying to help you diagnose the issue. Figure the issue out and then we can try and fix itGiving away "TSS" for FREE!!! Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 26, 2017 Author Report Share Posted June 26, 2017 3 minutes ago, rjdgriff said: It will not start with the plugs out. Right now I'm just trying to help you diagnose the issue. Figure the issue out and then we can try and fix it Giving away "TSS" for FREE!!! Okay, gonna pull them out right now, be back in a few mins with the results Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 26, 2017 Author Report Share Posted June 26, 2017 Gave it a good 30 kicks did not see anything come out of plug holes. Plugs are looking really black though. Not sure if that's okay. Quote Link to comment Share on other sites More sharing options...
ginger Posted June 26, 2017 Report Share Posted June 26, 2017 that means your jetting is really rich and your plugs are fouled. put in some new plugs gapped to .020 and it will fire a lot easier. 1 Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 26, 2017 Author Report Share Posted June 26, 2017 (edited) 43 minutes ago, ginger said: that means your jetting is really rich and your plugs are fouled. put in some new plugs gapped to .020 and it will fire a lot easier. I'm at a 310 right now on my main I believe.. I'm new to this 2 stroke/jetting stuff but how would I decide what is the correct jet size? A buddy of mine seems to think my reeds might have got fucked up.. I explained to him how the other day when I was getting back it was shutting off on me and I had to keep roll starting it till I got home. When I was home I tried kick starting and I heard a backfire, loud popping noise sounded like a fire cracker. hasnt started since that night, it was Friday night. e- I'm on cpis stock carbs with filters on them no airbox. Any other factors? Edited June 26, 2017 by Rawnold Quote Link to comment Share on other sites More sharing options...
ginger Posted June 26, 2017 Report Share Posted June 26, 2017 Elevation is a big factor as well as air temp. If you plugs fouled out, or if your super rich, it wont run great, especially the bottom end. Quote Link to comment Share on other sites More sharing options...
