Rapture Posted June 19, 2017 Report Share Posted June 19, 2017 My bike has started running a bit strange. If i run full throttle for say 10 seconds or more, then return to half throttle, then back to full throttle quickly it seems to bog down and i have to wait a few seconds and tease it back to wide open again. Could this be the carbs not filling up quick enough? I can't see it being a jetting issue IMO. Running it through the gears wide open is perfectly fine. Any ideas? Quote Link to comment Share on other sites More sharing options...
ginger Posted June 19, 2017 Report Share Posted June 19, 2017 whats your setup. motor carbs ETC so we can know a little about it. Quote Link to comment Share on other sites More sharing options...
Rapture Posted June 19, 2017 Author Report Share Posted June 19, 2017 (edited) 15 minutes ago, ginger said: whats your setup. motor carbs ETC so we can know a little about it. DMC 916 pipes, K&N filter, no lid on box. Carbs and engine otherwise stock. (TORS removed) 320 mains, clip on 4th position. 141 feet elevation, 28 °C at the time of ride. Edited June 19, 2017 by Rapture Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 19, 2017 Report Share Posted June 19, 2017 Possible scenario. It is starving for fuel. You are sucking the bowls dry and they recover when you let off. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted June 19, 2017 Report Share Posted June 19, 2017 ... Quote Link to comment Share on other sites More sharing options...
ginger Posted June 20, 2017 Report Share Posted June 20, 2017 either that, or do you think the RPM is dropping enough under half throttle that it is struggling to pull and needs to be down shifted? 6th gear the motor has to work a lot harder to recover the momentum Quote Link to comment Share on other sites More sharing options...
RoccothebeastQC Posted June 20, 2017 Report Share Posted June 20, 2017 slide or cable stock in some condition? it happened to me.... I polished my slide and no problem since... Quote Link to comment Share on other sites More sharing options...
Rapture Posted June 20, 2017 Author Report Share Posted June 20, 2017 22 hours ago, trickedcarbine said: Possible scenario. It is starving for fuel. You are sucking the bowls dry and they recover when you let off. This what i thought. On this basis though it should bog at WOT the first time, not on returning to WOT. So i don't think it can be this. Quote Link to comment Share on other sites More sharing options...
gusto Posted June 20, 2017 Report Share Posted June 20, 2017 (edited) What size pilot? Tried moving a clip on your needle? Does it bog when you get off the throttle a little or when you get off the throttle a lot? Edited June 20, 2017 by gusto Quote Link to comment Share on other sites More sharing options...
