Best carb set up for a 4mill ?
I'm currently running 28pwk , bike does rip really hard just feel I could and should be getting a little bit more , like it's bein choked back ;
Mods are 28mm pwk
4mill hot rods
ProDesign cool head , 150 psi I believe it's 22cc domes haven't verified yet looking to get 20cc soon @ sea level
Stock ported cylinders
CPI exhaust inframes
Chariot timing plate 4°
Chariot intake manifold with built in crossover
VF4 reeds
15/41
I can only gain 2-3 bike lengths on my brothers modded Trx450r drives me nuts because I know it can do way better but doesn't help I'm 6' 4'' 250
Should I be running 34-35 pjs ? What do you guys recommend
Mods are 28mm pwk
4mill hot rods
VF4 reeds
15/41
I run 35 PWKs on both our dune bikes. Similar set up.
I'd stay away from PJs.
Do you think I would notice a big difference stepping up from 28s Goin to 33or 35s I imagine it would wake up the mid to top end hopefully not sacrificing anything on the bottom
Jetted properly you would gain a little on too and I don't think you'll sacrifice the bottom. But I've never ridden anything with 28s for comparison.
I know my duner doesn't lack anything on bottom for duning and trail riding for my taste.
I'm busy with a very similar motor spec , but mines going into a 2 wheeler track bike
The software we used to port and build the pipes said I should run 34mm carbs
But as PWKs don't come in a 34mm I have opted for 33's which should give a bit more mid range power
i run 28's on my stock cyl, 4 mil stroker.  stock 450's are easy prey.
and my one buddy has a fully built trx450 and i can beat him every time, as long as i dont fuck up the launch.
Stock ported cylinders? Do you have proper 4 mil domes? Who did the port work?
That set up you have properly assembled and tuned should be hauling. Only a extremely built 450 should be a problem for you
Good question I was curious myself if it actually even had the stroker domes, getting ready to tear it down to verify how will I know when I do?
As far as the porting goes some guy in Texas built it according to the guy I bought it from apparently has built many banshees and he ported the cylinders himself I can tell because there's gouges and slips here and there...
And by all means this bike does haul
When I can launch it correctly but like I said before I think my weight is not helping being 250 pounds
Well that might be you issue there. You could not be ported correctly or set up Correctly.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Hmmm I might just re-build this engine so I know it's done right who sells a top notch drop in ported and ready to go 4 mill kit
There's tons of them on eb can I trust any of them
One of our many site sponsors. Call fast, red line, driveline, and whoever else is on the list. It gets kings every time I check it
  • Like 1
