Brembo Brake Upgrade
I am using a front caliper as my rear brake, it looks much cleaner in my opinion and I had a custom brake line made with a 90 degree elbow in it so the stock line wasn't a tangled mess in the rear. One thing to note is if you use a front caliper on the rear you have to use the slide pins from the front caliper but you have to use the base mounting plate from the rear caliper. It bolts to the pins of a front caliper but it allows it to actually fit the stock rear caliper mount otherwise it would be too narrow. Oh and you either have to bleed it off of the quad with an old rotor wedged between the pads or I just used a vacuum bleeder and it worked like a charm and didn't have to mess with removing it.0618171852_1.jpg0618171851b.jpg
