98 banshee not running right
by air leaks, meaning the motor could be sucking air,  check that your carb boots arent riped. that intake gaskets are good, ever base gaskets, or pressure test it.  there is a thread on how to do that with simple home depot stuff.
On 6/15/2017 at 5:31 PM, gusto said:
What VF reed?  If its a 4 try a 30 pilot.  Is it stroked?  360 main sounds big for a stock stroke unless its really ported up.
I put a set of 280 main jets in. Now when I rev it, it sounds like it wants to die. Also when trying to hit the powerband while driving it backfires. Do you guys think it's the CDI?? Tested the coil and its fine I'm maybe thinking it's that?
i have heard of being to lean causing backfiring.
quick question,  how clean is your air filter.  I had midrange issues at one point because i had an outerwear go bad, and it was like putting a bag over the air cleaner.
