Rawnold Posted June 16, 2017 Author Report Share Posted June 16, 2017 42 minutes ago, ginger said: do you have the correct number of friction and steel plates in the clutch? if i had it all ripped appart, i would have put a pancake bearing in there, so you dont have to worry about the ball seizing. as for throttle sticking, does the cable move freely, and does it have any sharp kinks in the cable or is it all smooth curves? I thought pancake was for high hp builds at least that's what my buddy told me. But I have 7 big and 6 little plates. Started with a big ended with a big. & the cable is smooth & no kinks or something like that it feels even a little stiff but besides that and the bit of free play it works fine Quote Link to comment Share on other sites More sharing options...
ginger Posted June 16, 2017 Report Share Posted June 16, 2017 pancake is good for any setup. keeps the ball from welding especially if you have to ride the clutch at all. big HP guys normally just automatically put them in there. Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 16, 2017 Author Report Share Posted June 16, 2017 So just got back home and it's doing the same thing. It's like every time I take off on it real fast the clutch goes to shit.. I have to pop it into gears without using the clutch cause even if I pulled it, you can feel the engine still going like nothing happened.. until clutch randomly pops back in on 1st or 2nd gear. Then I can shift normally again.. what's happening?? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 17, 2017 Report Share Posted June 17, 2017 Jfc Quote Link to comment Share on other sites More sharing options...
Rawnold Posted June 17, 2017 Author Report Share Posted June 17, 2017 So just got back home and it's doing the same thing. It's like every time I take off on it real fast the clutch goes to shit.. I have to pop it into gears without using the clutch cause even if I pulled it, you can feel the engine still going like nothing happened.. until clutch randomly pops back in and then I can shift normally again.. what's happening?? I notice the acceleration gets a bit weird when the clutch goes out.. Anyone?? Quote Link to comment Share on other sites More sharing options...
Big_drin Posted February 28, 2022 Report Share Posted February 28, 2022 I had the same issues with my cable. I went through my whole clutch system and now use half oem and half heavy duty springs. I bought a motion pro cable that was also a tad too long. The only thing that really helped out was a new asv clutch lever with the adjustable perch. It has an extra piece to extend the length of your perch and it also has adjustability to push your lever out further away from your handle bar grip to add to the length of the pull. That’s what fixed my problem. It’s the asv F2 model with the perch included. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 1, 2022 Report Share Posted March 1, 2022 Did you get a call from 2017 too? cray cray Da fuq is fb down or sumpin? Quote Link to comment Share on other sites More sharing options...
