xelerated Posted December 11, 2003 Report Share Posted December 11, 2003 Oilsmoke- I can't find my calipers, but it is EXACTLY 1-3/8" from the center of the small radius in the exhaust port to tht top of the cylinder- hope that helps! Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted December 11, 2003 Report Share Posted December 11, 2003 Really? Man the one I'm doning is like 1.170 right now and I only took off about .030 or so. I think stock is 30.5mm X .0395 =1.20475 i think 1 3/8 in like 1.375 Hmm I wonder.??? Quote Link to comment Share on other sites More sharing options...
xelerated Posted December 12, 2003 Report Share Posted December 12, 2003 LOL! My bad- It measures 1 5/32" from the top... Quote Link to comment Share on other sites More sharing options...
95prerunner Posted December 14, 2003 Report Share Posted December 14, 2003 I was reading the posts about the racelogic porting. you guys have convinced me Iam going to order it on monday. One question will I have to use a higher octane fuel, I run premium 91 now. I have 21cc domes,FMF fattys,carbon fiber reeds,and Iam going to rejet with pro-tec performance jets 410s. The jet is big but the needle is designed different, it is shorter. thanks for any info. I can't wait Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted December 14, 2003 Author Report Share Posted December 14, 2003 i have the same mods as you except i have the vforce 2 and fmf sst's with stock carbs and i run 93 octane and it still rips. Quote Link to comment Share on other sites More sharing options...
dirtbike killer Posted December 14, 2003 Report Share Posted December 14, 2003 Your psi is what you go off for the type of gas to run, and porting will lower your psi. Most of the time you want to go to smaller domes to offset this. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted December 14, 2003 Report Share Posted December 14, 2003 douse the race logic kit tell you any thing about the transpher ports or the exughst becouse that is where most of the power is gained when porting a motor Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted December 14, 2003 Author Report Share Posted December 14, 2003 douse the race logic kit tell you any thing about the transpher ports or the exughst becouse that is where most of the power is gained when porting a motor just the intake and exhaust window, its the only thing it gives the templates for. This is not supposed to be an all out full drag port job. The guy at race logic told me this is the type of porting you want if you want power and reliability. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted December 14, 2003 Report Share Posted December 14, 2003 i would love to see how a dyno from befor and after like if you had a stock set of cylinders and threw the ported ones right on so it would be acurate just curiose on how much power is gained by the porting couse i haev always been told its hard to gain much power withought getting into the transphers just wondering how much power do you think it increesed was it like putting pipes on ? Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted December 14, 2003 Author Report Share Posted December 14, 2003 i would love to see how a dyno from befor and after like if you had a stock set of cylinders and threw the ported ones right on so it would be acurate just curiose on how much power is gained by the porting couse i haev always been told its hard to gain much power withought getting into the transphers just wondering how much power do you think it increesed was it like putting pipes on ? Im sure its not a huge gain but it is a huge difference. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted December 14, 2003 Report Share Posted December 14, 2003 Jethro Just roughing up the intakes, Narrowing the center bridge alittle, knife edge the transfers dividers and Polishing the exhaust port without cutting the windows one bit will make a big difference in the shee powerband personality. Quote Link to comment Share on other sites More sharing options...
95prerunner Posted December 16, 2003 Report Share Posted December 16, 2003 hey erbilabuc do you think I should port then bore or bore then port. The bores are pretty bad but will clean up going 30 over. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted December 17, 2003 Report Share Posted December 17, 2003 Port than Bore. Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted December 17, 2003 Author Report Share Posted December 17, 2003 what oil smoke said. Your situation is perfect in case you gouge the cylinder in a mistake . port then bore Quote Link to comment Share on other sites More sharing options...
SickAssDMCBanshee Posted December 17, 2003 Report Share Posted December 17, 2003 Thanx for the great info. Since I decided to keep my shee and not sell and get a YFZ 450. I'm going to do what I can to make my shee more enjoyable. I'll tear it down and try this for sure, after I finish my suspension set up so I can get a handle on what I've already done to the Shee. Quote Link to comment Share on other sites More sharing options...
