Paddles are Honda bolt pattern, different hubs?
I bought these paddles for my Banshee, got them for a great deal but the guy lied and said they were Yamaha bolt pattern. They appear to be Honda, because they are a smaller pattern. Would I be able to put 400ex hubs on and throw those paddles on? I know Banshee hubs fit on a 400ex axle for sure, iv'e done that.
You pretty much answered your own question
I was wondering about the length of the 400ex hub, not the spline pattern. I know that the banshee hub is shorter in overall length than the 400ex's, so if I put the 400ex hub on I wonder if I'll be able to even thread on the castle nut. Sorry, should have been more specific.
You could also drill between the Honda pattern for a yammy pattern. I have a couple of sets of tires that have both patterns.
And yours studs are bigger?
Banshee is 4/115 and 4/156(big hub rear)
Blaster is 4/100
400ex is 4/110.
If all your studs are off by 1/2, you might have the big rear hub.
Big rear hub? I didn't know there was anything else than just the regular rear one. And no, the studs are the right size for the holes.
Edited by LukeSandiefer
Blaster is 4/100
400ex is 4/110.
I also though the older years (87-89?) had a larger pattern.
I think it was 89-90 that had the big hub. I am not 100% but I am pretty sure it wasn't the first years. I had one, talk about a bitch to find rims for it.
Yeah, I didn't remember either. Would be well worth it to pitch the hubs and run the more common one. But if you've got a set of rims with the odd pattern, they might be worth something to somebody.
If the studs are 1/2-3/4" from lining up, there is no way you have 400ex pattern (4/110) on the wheels with banshee (4/115) hub. This would be the bolts are only 2.5mm off from lining up. 2.5mm is less than 1/8" off. To be 3/4" off (19mm) you could have 4/115 on wheels with 4/156 on hubs. This would be 20.5mm from each bolt lining up with the hole.
Okay, so I will measure when I get home and get back to you. So you're saying that I might have the older style big hubs?
