big4mill Posted May 2, 2017 Report Share Posted May 2, 2017 My banshee has a +10" swingarm with a strut with no link . I want to put a shock on it . Any ideas what I need to run ? Will a Marvin Shaw work it will be laying pretty flat will it hold up ? I don't care if it is stiff just want alittle give Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 2, 2017 Report Share Posted May 2, 2017 If you're doing a No link, it's best to set it up with a new upper perch that allows the shock to be more vertical. If you decide to do a laid down shock from the swing arm to the factory upper shock mount, it will take a quality shock or Marvin that is set up with that in mind. Typically when people use a lay down set up, the ass of the bike will lurch up and the nose will dive. So it takes valving to correct that behavior. Quote Link to comment Share on other sites More sharing options...
