ClaudeMachining Posted May 2, 2017 Report Share Posted May 2, 2017 Hi, i'm doing an exhaust clamp and i'm looking for high temp silicon tubing with 1" ID. I already got tubing from McMasterCar, but it's only rated 400F (the maximum they got) and i'm not sure if it's enough. Any help finding higner rated tubing??? Thx. NB: the new clamp will be tits and 100% leak free! Quote Link to comment Share on other sites More sharing options...
Schweet97Z Posted May 2, 2017 Report Share Posted May 2, 2017 http://firesleeve.gomo.pro/?return_to=http://www.firesleeveandtape.com/ Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Schweet97Z Posted May 2, 2017 Report Share Posted May 2, 2017 Maybe they can get you pointed in the right direction Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 2, 2017 Author Report Share Posted May 2, 2017 I've heard hydraulic hose works. But to be honest I always order mine from Toomey. Yeah, but they tend to crack and they are too thick for what i want to do. By now, i find some 500F rated but they dont go beyond 7/8" ID or they sell it by 100 feets long... Quote Link to comment Share on other sites More sharing options...
J-Madd Posted May 2, 2017 Report Share Posted May 2, 2017 What about the stuff F.A.ST. sells? http://farmandsandtoys.com/ocart2/categories/exhaust-pipes Sent from my STV100-1 using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 2, 2017 Report Share Posted May 2, 2017 Hit up Jeff at Fast. Pretty sure he'll sell it in bulk. Quote Link to comment Share on other sites More sharing options...
Keno Posted May 2, 2017 Report Share Posted May 2, 2017 Pretty sure everyone uses standard silicone heater hose. Like Flexfab 5526 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 2, 2017 Author Report Share Posted May 2, 2017 Those like the fast have are easy to get. But they have more than 1/8 wall. I want 1" id and 1.25od Quote Link to comment Share on other sites More sharing options...
Keno Posted May 3, 2017 Report Share Posted May 3, 2017 http://www.ebay.com/itm/321335857328 maybe the 25x31mm? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 4, 2017 Author Report Share Posted May 4, 2017 http://www.ebay.com/itm/321335857328 maybe the 25x31mm? Nice find man, I will order some to try them. Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted May 5, 2017 Report Share Posted May 5, 2017 Fluid connectors has high temp silicone hose that works well its blue with a red center.. used it for years and no melting issues.. not sure if you have a fluid connectors in Canada but most ag shops will stock it. Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted May 5, 2017 Report Share Posted May 5, 2017 (edited) The hardest thing about the billet clamps is the fitment and trying to get them in all the way. I think a 2 piece clamp with a step from front to rear would work great. Slide the hose on, get the pipes fitted, then bolt on the 2 piece clamp to sucure.. jmo Edited May 5, 2017 by JUSTWANNARACE Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 5, 2017 Author Report Share Posted May 5, 2017 The hardest thing about the billet clamps is the fitment and trying to get them in all the way. I think a 2 piece clamp with a step from front to rear would work great. Slide the hose on, get the pipes fitted, then bolt on the 2 piece clamp to sucure.. jmoI already addressed than in my new clamp ;-) Others use a thicker rubber to compensate the diameter difference between pipe and stinger and that's why some people have hard time to make them leak free. My clamp got dual inner diameter with a nice round transition. Thats why im able to use a thiner tube. You will have a right and a left clamp. I'm in my bath right now, I'll make you a drawing later to be sure we understand each other. Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 5, 2017 Author Report Share Posted May 5, 2017 Look like this. I don't need a thick walled rubber, that's why I don't want to use the 'common' one. Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted May 6, 2017 Author Report Share Posted May 6, 2017 Working perfectly!! I hope the 390F rated hose will work. I'm not looking for a hose to work at least one season. Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
