iLLiCiT Posted May 1, 2017 Report Share Posted May 1, 2017 I just tore down my banshee motor after it locked up, one of the screws from the clutch basket backing plates came out and got jammed up in my gears. When pulling off the clutch cover this small spring was sitting in the engine. I haven't been able to find out where it came from by looking through the manual. Anyone got an idea of where it came from? http://imgur.com/a/U8MtO 1 Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 1, 2017 Report Share Posted May 1, 2017 I just tore down my banshee motor after it locked up, one of the screws from the clutch basket backing plates came out and got jammed up in my gears. When pulling off the clutch cover this small spring was sitting in the engine. I haven't been able to find out where it came from by looking through the manual. Anyone got an idea of where it came from? http://imgur.com/a/U8MtO Looks like a spring from around the inside of a seal. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
iLLiCiT Posted May 1, 2017 Author Report Share Posted May 1, 2017 Thanks that looks like what it is. Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted May 1, 2017 Report Share Posted May 1, 2017 Looks like a spring from around the inside of a seal. Sent from my iPhone using Tapatalk Yep its the spring off the crank seal.. have to split the cases and install new seals. Quote Link to comment Share on other sites More sharing options...
iLLiCiT Posted May 6, 2017 Author Report Share Posted May 6, 2017 When pulling the primary drive gear nut off the crank I noticed mine didn't have the conical washer, It has a hotrods crank in it so Im not sure if those cranks just don't have those or whoever owned this before me put it together wrong. Would anyone here know off hand? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted May 6, 2017 Report Share Posted May 6, 2017 When pulling the primary drive gear nut off the crank I noticed mine didn't have the conical washer, It has a hotrods crank in it so Im not sure if those cranks just don't have those or whoever owned this before me put it together wrong. Would anyone here know off hand?They all have that washer. Yours is missing. You may as well get one to go back in. Sent from my STV100-1 using Tapatalk Quote Link to comment Share on other sites More sharing options...
iLLiCiT Posted May 7, 2017 Author Report Share Posted May 7, 2017 They all have that washer. Yours is missing. You may as well get one to go back in. Sent from my STV100-1 using Tapatalk Thanks Quote Link to comment Share on other sites More sharing options...
