hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 Pic won't upload. What does this do unplugging it? Unplug the tores also? Either unplug it or plug the other 2 on the carbs back in. Quote Link to comment Share on other sites More sharing options...
Brandonb028 Posted April 30, 2017 Author Report Share Posted April 30, 2017 I already had them plugged in I can try unplugging them. I don't see that dot on the slide ether in the picture. Is it only on one slide? If so which one? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 Both, if you have one in backwards, you have them both in backwards. They only go in the wrong way in the wrong carb. The windows are both on the right sides of the carbs IIRC Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 The dot is not in the picture, the cut-out that should face the air filter is. Quote Link to comment Share on other sites More sharing options...
Brandonb028 Posted April 30, 2017 Author Report Share Posted April 30, 2017 Ok gotcha. Then there right throttle works fine slides easy. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 Working easy has nothing to do with being backwards. But if you marked them should be good. Are you sure you put the hose on the correct nubs on the carbs? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 We're quickly working our way down to Gas on? Gas in tank? LOL It's happened 1 Quote Link to comment Share on other sites More sharing options...
Brandonb028 Posted April 30, 2017 Author Report Share Posted April 30, 2017 Yep. Not able to give me a call are ya lol Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 How long did you try to pull start without that crossover hose to get really hot? That's a huge air leak and could have done considerable damage. Quote Link to comment Share on other sites More sharing options...
Brandonb028 Posted April 30, 2017 Author Report Share Posted April 30, 2017 No super long. What kind of damage are we talking? Quote Link to comment Share on other sites More sharing options...
Brandonb028 Posted April 30, 2017 Author Report Share Posted April 30, 2017 It didn't get hot enough to blow it up I Mean it tried to bump it and back fired and fell on its face and i stopped. Didn't let it over heat. Have 110psi ish on both cylinders on compression t st also Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 30, 2017 Report Share Posted April 30, 2017 I would hope none, but I've tried to pull start something until it was "really hot" Without that hose the motor won't be able to draw fuel, so it would be super lean. Might at least try new plugs. That hose not being there should have been your issue and putting one on, it should have started right up. Quote Link to comment Share on other sites More sharing options...
Brandonb028 Posted April 30, 2017 Author Report Share Posted April 30, 2017 Tried the hose and tried kicking and pull starting again with no luck. It doesn't even really try to fire it just pops really bad. Installed new plugs(without hose on) havnt tried new plugs with hose on now. New plugs are very black also. New plugs again with hose on? Quote Link to comment Share on other sites More sharing options...
Brandonb028 Posted May 1, 2017 Author Report Share Posted May 1, 2017 Put new plugs in and still nothing Quote Link to comment Share on other sites More sharing options...
