Banshee carb problem
Holy hell! $450?????
Sent from my VS990 using Tapatalk
I just bought one of those this week. I hope to hell I didn't pay $450 for it!! Pretty sure the normal price is $45.
Sent from my STV100-1 using Tapatalk
I had a buddy who bought a decent leak down kit off eBay once for $30. It's no motion pro set up, but it worked.
Sent from my SM-S820L using Tapatalk
I bought the expensive Motion Pro one and the fucker didn't work right out of the box.
  • Like 1
Really? That's my luck all day lol. Good to know though. Ive always wanted to buy one, but my homemade job works.
Just got this in. What a coincidence. However, he was supposed to send some bigger fittings for 39mm carbs. But no big deal now that I have these parts I can just go by the hardware store and show them what I need. I've never built one of these my self because I don't know what this stuff is called or where to look for it. 533891d87dfac771c2bf80c2ef8d25db.jpg
  • Like 1
Do those parts come with part numbers going to try and make my own today. Really thinking it's my crank seal that's bad. Sucks just had this thing rebuilt about 4 tanks threw it
Remember.....now more than 6psi!!! Or else you start doing more bad than good. Also soapy water in a spray bottle will help you find leaks if your pressure isn't holding. You ideally (if I remember correctly) want to see no ore than 1psi drop per minute. Obviously its better if it holds for a long time.
Okay so I did a compression test since I hadn't done one yet and think I found issue. Getting about 100 psi on left the side that's smoking a lot and 120 on right side.. stock jugs and bore and stock head
