dkota12200 Posted April 5, 2017 Report Share Posted April 5, 2017 Hello, i have stock carbs with the tors delete so i just have the cap and the cable. Now my problem is when i pull the throttle lightly my right slide goes up a little then my left will lift. So whats my problem is my carbs out of sync? Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted April 5, 2017 Report Share Posted April 5, 2017 Yes you are correct. Do you have a service manual or Clymers manual. Not hard to sync. Sent from my LG-H831 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted April 5, 2017 Report Share Posted April 5, 2017 *edit* also check your throttle cable from bars to the carbs to make sure not twist or kinks of that nature. Sent from my LG-H831 using Tapatalk Quote Link to comment Share on other sites More sharing options...
spurdy Posted April 5, 2017 Report Share Posted April 5, 2017 You can sync them by eye and get them close. Or get a carb sync tool and sync them by air flow which is more accurate. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dflynn926 Posted April 5, 2017 Report Share Posted April 5, 2017 You want to sync them, there are a bunch of detailed threads on here or YouTube, on how to sync them. I had the same issues, when I deleted my tors Quote Link to comment Share on other sites More sharing options...
