99cobrasvt Posted March 18, 2017 Report Posted March 18, 2017 Ok my question is I always mixed 24:1 for like 10 years with Yamaha oil 2R racing I switched from that to ams oil saber mixed at 80:1 I had to go down from my 310 mains to 280s now the bike won't start good when it's hot in hot weather and won't rev till I give it Alota gas !! Then it works awesome !! Drives fine as soon as I shut it off gota kick it and give it gas a bunch to start is it the pilots off needle or airscrews ??? Its a 2003 banshee it's mint heads were never off compression perfect bike runs awesome well it did. Mods are toomey t5s 2 into 1 filter dynojet needle 280 mains at sea level in about 80 degrees rest is stock I bought the bike new pipes were on it 12 years ! Any help I'm stuck Quote
bigweav81 Posted March 18, 2017 Report Posted March 18, 2017 24:1.................to 80:1? Sent from my SM-S820L using Tapatalk Quote
sheerider11 Posted March 18, 2017 Report Posted March 18, 2017 24:1.................to 80:1? Sent from my SM-S820L using Tapatalk EPA probably thanks him 2 Quote
Ayesully810 Posted March 18, 2017 Report Posted March 18, 2017 StrmTrooper where u at. Hit em with it Sent from my LGMS210 using Tapatalk 1 Quote
trickedcarbine Posted March 18, 2017 Report Posted March 18, 2017 Starting is typically based on the Pilot Jet. You need at least a 27.5 pilot. The fact that you need to give it has to get it to start is the motor telling you it needs more fuel. Quote
Davy's Grin Posted March 18, 2017 Report Posted March 18, 2017 I honestly didn't think you could run 80:1 Ina banshee I run 50:1 with amsoil dominator. Aslo what made you change to a different oil? from the depths of oblivion Quote
99cobrasvt Posted March 18, 2017 Author Report Posted March 18, 2017 Ams oil saber recommends 100:1 I run 80:1 running it for 2 years no issues ! Clearner buring no fouling plugs just seems rich now on my low end less oil more gas then 24:1 so I know I'm rich! When I switched the 310 mains I had were wayyy to rich bike was sputtering running hot ! Went down 2 sizes then the 3rd and I'm good now just the low end circuit isn't right only for starting when bike is hot and air temp is hot drives fine! Just wondering if anyone is running this and what do they do for jetting I guess Quote
sleeper06 Posted March 18, 2017 Report Posted March 18, 2017 Stop running that ratio, I know the bottle says you can. I take apart a ton of engines and can always tell when someone is running funky ratios. Run the dominator at 32:1 and your crankshaft will thank you. Your internal parts depend on that oil . If your looking for performance gains look somewhere else. Just my opinion. Quote
99cobrasvt Posted March 18, 2017 Author Report Posted March 18, 2017 And I think my pilot is too rich not to lean I changed from 24:1 to 80:1 made my gas and oil mixture leaner but my air fuel ratio is wayyyyyyy richer so I gota back off on jetting do smaller just though maybe someone had this issue Quote
99cobrasvt Posted March 18, 2017 Author Report Posted March 18, 2017 It's my 3rd banshee and I'm been running it for 80:1 for 2 years no prob so I feel it's safe that's not the prob works awesome and I did plug chops again last summer and everything looks great Quote
Ayesully810 Posted March 18, 2017 Report Posted March 18, 2017 Y u post for help then u no listen to helpz on here Sent from my LGMS210 using Tapatalk 2 Quote
99cobrasvt Posted March 18, 2017 Author Report Posted March 18, 2017 I am asking for help I was wondering if anyone had an issue like that Quote
Ayesully810 Posted March 18, 2017 Report Posted March 18, 2017 Why dont you just run 32:1 like all the normal ppl around here. Sent from my LGMS210 using Tapatalk Quote
bigweav81 Posted March 18, 2017 Report Posted March 18, 2017 Try 100:1? Sent from my SM-S820L using Tapatalk 3 Quote
Strm Trpr Posted March 19, 2017 Report Posted March 19, 2017 StrmTrooper where u at. Hit em with it Sent from my LGMS210 using Tapatalk I read this dog shit this morning and I didn't want to get involved. 2 Quote
