dalegoldston Posted March 13, 2017 Report Share Posted March 13, 2017 Just installed a serval. Old shit never did this. I'm at Little Sahara here in ok. First blew the top hose, sounded like a shotgun. Fixed that went back out noticed steam now the back hose on my cool head was expanded like a Ballon. Do servals run that hot? Why did the over flow not blow coolant? Quote Link to comment Share on other sites More sharing options...
camp0429 Posted March 13, 2017 Report Share Posted March 13, 2017 If its building that much pressure I would try switching the radiator caps and see what happens 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 13, 2017 Report Share Posted March 13, 2017 Water pump working correctly? You might pull the cover and make sure it's not melted. Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted March 13, 2017 Author Report Share Posted March 13, 2017 I'll check that. Think I can find a new cap here at the dunes? Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 13, 2017 Report Share Posted March 13, 2017 Wow... Make sure the motor isn't cooked. Compression test and definitely take a peek at the pump. Then verify the jets are adequate and it's not lean. Check for air leaks, does it idle high or slow to return to idle? It shouldn't be that hot. Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted March 13, 2017 Author Report Share Posted March 13, 2017 Just had it jetted on a dyno. It was fine before I swapped to the serval cylinders. Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
guns4children Posted March 13, 2017 Report Share Posted March 13, 2017 Just had it jetted on a dyno. It was fine before I swapped to the serval cylinders. Sent from my SAMSUNG-SM-G890A using Tapatalk Sooooooo..... You had the serval cylinders jetted on a dyno? Sent from my XT1080 using Tapatalk Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted March 13, 2017 Author Report Share Posted March 13, 2017 Well technically the carbs were jetted. So I'm pretty confident it's good on that. Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 13, 2017 Report Share Posted March 13, 2017 Not necessarily true. A dyno is a tuning tool but that doesn't mean it'll be the same in the real world. I bet you're lean. Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted March 13, 2017 Author Report Share Posted March 13, 2017 Well that sucks if I fried my shit. I thought the dyno put that on dead nuts not just close. Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 13, 2017 Report Share Posted March 13, 2017 Well that sucks if I fried my shit. I thought the dyno put that on dead nuts not just close. Sent from my SAMSUNG-SM-G890A using Tapatalk A dyno can get you close, but the sand puts a huge load on the motor, which is different than the load from the dyno. What carbs and jetting? Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted March 13, 2017 Author Report Share Posted March 13, 2017 Single 35 Pwk. 210 main I believe is what he said. Not sure about the pilot. I didn't ask but should have. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 13, 2017 Report Share Posted March 13, 2017 Fuck, I have zero experience with a single carb setup... Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted March 13, 2017 Author Report Share Posted March 13, 2017 Maybe it was the same for the dyno guy. I'll pull the plugs in the morning and look. Does that do any good if not looking at them from a plug chop? Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted March 13, 2017 Author Report Share Posted March 13, 2017 I think you have an issue if your setup only made 50 which is less than your old stock cylinders made.I was thinking that as well. But have no clue as what could be wrong. Unless it was with the dyno. Quote Link to comment Share on other sites More sharing options...
