Bike has pro circuit pipes, ported motor @58 ish hp. Single  pwk35 keihin carb with 190 main. Think this is a descent starting point or need to go bigger. I feel I was running a bit fat on the old cylinders.
is that what you ran on the serval
I think he is saying the carb he has now was on his serval motor. Now it's on his ported stock cylinders. And curious if the jetting will be off.
I asked that in my very first question and he said no?
Sorry, my excellent explaining skills at their best. I had on my quad a set of ported cylinders @58 ish hp, pro circuit pipes, v-force 4 reeds, single pod filter, no air box, Single  pwk35 keihin carb with 190 main,
57 pilot ??(have to verify this) I just installed a serval  stock stroke and was asking if the above was a good starting point for jetting or if its going to be way off. I did fire it up tonight. But did not run it down the road.
Sorry I should have stated had ported oem cylinders, now have serval cylinders.
So you have ported OEM cylinders with Pc pipes and a single pwk35mm carb?
What manifold you running? Airbox or pod filter? Any other mods?
ok cool, the serval should be slightly more efficient on fuel. If it was jetted for your altitude, it SHOULD be close and possibly rich. (If serval was jetted properly for your altitude and current temp) All the same, I would jet up a touch, run it on new plugs 1-5or 6 if you can and shut it down. Pull plugs, post pics for us of plugs and we can guide you from there.
  • Like 1
I did not see will have to wait to till I get back home. I was disappointed with the hp numbers though. Right at 50. Was expecting more. I have to keep the revs higher as well.
Edited by dalegoldston
