Lifetime banshee Posted March 6, 2017 Report Share Posted March 6, 2017 Do i need to change stock piston to run a dome head on a cool head? And what cc dome would i need to use on stock motor without switching to racing gas and get the most compression? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted March 6, 2017 Report Share Posted March 6, 2017 Do i need to change stock piston to run a dome head on a cool head? And what cc dome would i need to use on stock motor without switching to racing gas and get the most compression?Need to know your elevation to give accurate answer on cc. You don't have to change piston. Just make sure whomever you order from knows what piston you're running. Quote Link to comment Share on other sites More sharing options...
Lifetime banshee Posted March 6, 2017 Author Report Share Posted March 6, 2017 I dont know if this motors been touched so i beleive im running stock pistons. Whats better to run the stock piston or dome piston? Quote Link to comment Share on other sites More sharing options...
Ducman Posted March 8, 2017 Report Share Posted March 8, 2017 I dont know if this motors been touched so i beleive im running stock pistons. Whats better to run the stock piston or dome piston? All pistons have a dome shape to them. There is only a couple of things that could cause you to need to run a special dome and that would be if you have a stroker crank or after market cylinders like cub or serval cylinders. Most likely you just have stock cylinders/pistons so you can run standard off the shelf domes. If you are 3000 ft elevation or higher you could run 21cc domes on pump fuel. If you are sea level to 3000 ft you should run 22 cc domes. No jetting changes are required for increased compression but when you increase compression you increase the chance for detonation so you want to make sure you are not running too lean on the main jets. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 9, 2017 Report Share Posted March 9, 2017 Not all pistons have a dome. Some are flat. Sent from my SM-S820L using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 9, 2017 Report Share Posted March 9, 2017 Not all pistons have a dome. Some are flat. Sent from my SM-S820L using Tapatalk Shhhhhh Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 9, 2017 Report Share Posted March 9, 2017 My bad lol. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lifetime banshee Posted March 9, 2017 Author Report Share Posted March 9, 2017 Thanks for the reaponse mine has been jetted by a dealer but im unaware of what. I live in upstate ny and i wanna run the wiseco kit. It has been piped and jetter Quote Link to comment Share on other sites More sharing options...
Ducman Posted March 9, 2017 Report Share Posted March 9, 2017 Not all pistons have a dome. Some are flat. Sent from my SM-S820L using Tapatalk Show me a flat top piston for use in a banshee. Were not talking about 4 strokes here. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 9, 2017 Report Share Posted March 9, 2017 FFS.......... Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 9, 2017 Report Share Posted March 9, 2017 FWIW. I wasn't trying to argue.....just stating facts. It's all good though now you know. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 10, 2017 Report Share Posted March 10, 2017 Show me a flat top piston for use in a banshee. Were not talking about 4 strokes here.358banshee did some a while back. I think there were quite a few T Rex's with flat tops. Not a very common thing, but it's been done. Quote Link to comment Share on other sites More sharing options...
Mr.Midnight Posted March 10, 2017 Report Share Posted March 10, 2017 Unbolt your head, conferm what piston is in your engine, stock or ? Then i would call driveline performance and have a proper set of domes made for your banshee. They are sharp guys and will help u out with that. Also thiers a big diff between "off the shelf domes" and a custom set built for your engine. Sorta sounds like your new to banshee mechanics? Dont mean to be a jerk just from what im reading in the post, if so u might be better off finding a sight sponser in your area and have them do the domes for ya. Thiers a bit more to it then just slappin "domes in" hope this helps man. Quote Link to comment Share on other sites More sharing options...
