Melted piston?
Should've done a leak down test before tear down, but we've all probably been hasty to tear one down and forgot at one point. If the bore is ok you can run a hone through it and put a new piston in there. Test for air leak before starting and also report your mods and jetting specs.
  • Like 1
Ill try to clean the jug tomorrow but they have a bit of material from the piston on them. I think ill have to bore to 65mm
May try some muratic acid on the bore. It will take the aluminum off. But I bet you're bore is scarred if that happened.
