BUSA RIDER Posted February 26, 2017 Report Share Posted February 26, 2017 I'm building a 4 cylinder engine out of an rd350 (don't have two banshees engines). For starters does anybody know if a banshee lockup is the same or will work on an rd Appreciate all the help I can get thanks in advance 4cyl h2 Quote Link to comment Share on other sites More sharing options...
Keno Posted February 26, 2017 Report Share Posted February 26, 2017 same Quote Link to comment Share on other sites More sharing options...
BUSA RIDER Posted February 26, 2017 Author Report Share Posted February 26, 2017 Exact? Even uses 5 mm bolts for the springs? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 26, 2017 Report Share Posted February 26, 2017 I think rd stuff is slightly different, rzstuff is closer . Quote Link to comment Share on other sites More sharing options...
BUSA RIDER Posted February 26, 2017 Author Report Share Posted February 26, 2017 Never could figure out how to post pictures but be glad to email u some of my progress so far Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 26, 2017 Report Share Posted February 26, 2017 Oh boy 1 Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted February 26, 2017 Report Share Posted February 26, 2017 Never could figure out how to post pictures but be glad to email u some of my progress so farTapatalk Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
BUSA RIDER Posted February 27, 2017 Author Report Share Posted February 27, 2017 Hey Keno. U sure? Quote Link to comment Share on other sites More sharing options...
Keno Posted February 27, 2017 Report Share Posted February 27, 2017 Crap, I was thinking rz350. I have no idea of the rd. My bad. Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
BUSA RIDER Posted February 27, 2017 Author Report Share Posted February 27, 2017 Nothing to it. Thanks I can buy one for a banshee cheap. Making ones a lot of work Quote Link to comment Share on other sites More sharing options...
BUSA RIDER Posted February 27, 2017 Author Report Share Posted February 27, 2017 Are the spring bolts 5 mm thread Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 27, 2017 Report Share Posted February 27, 2017 Are the spring bolts 5 mm thread If you are referring to the 6 bolts that hold on the pressure plate, by the part number they are 6mm on a Banshee. 90159-06016-00 Quote Link to comment Share on other sites More sharing options...
BUSA RIDER Posted February 27, 2017 Author Report Share Posted February 27, 2017 Do you know if rest of dimensions are same? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 27, 2017 Report Share Posted February 27, 2017 This will be a cool project if it takes off. But if you were truely capable of this build, you would be able to answer some of these questions. Start dwelling around on the RZ/RD forums, they will be a goldmine of info for stuff like this. 1 Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 28, 2017 Report Share Posted February 28, 2017 I know for a fact the rd is different, splines are different for hubs. Not sure dimensional size. Any reason your not using banshee cases. There cheap compared to other issues with rd stuff. Clutch actuators are different and crank shaft dimensions looked different also . I will tell you a stock rd crank is beefy in comparison to a shee crank 1 Quote Link to comment Share on other sites More sharing options...
