What exactly are you trying to do?  I would just remove the carbs, take the fuel bowl off and thoroughly clean the carbs with carb cleaner.  There isn't anything that typically needs to be replaced.  I would only buy carb parts as needed.  About the only thing that might need to be replaced over time is the fuel lines and the float valve but if it isn't leaking then I wouldn't replace it.
  • 2 months later...
If rejetting only use keihn or mikuni jets. The float is adjustable and there is a spec it needs to be at. Over time the float valve might get a groove in the point... just get one made by mikuni or keihn.
