Proud first time banshee owner my build is coming along very well but I need help with the size jets I should start with my build consist of 4mill crank dune ported stock cylinders 19cc domes vitos cool head pro circuit platinum pipes pwk 33 carbs plus 4 timing all advice would be appreciated
You will need straight 110 with those domes pretty close to 14:1. I would start 165 main 50 pilot , dek needle middle slot . . These settings will be good to heat cycle and test ride in order to plug chop . Depending on porting you might end up with a cel needle but my portwork loves the dek. If your a newb make sure you pressure test your engine after assembling, then check compression, squish. Also ohm out all electronics
