penguin Posted February 15, 2017 Report Share Posted February 15, 2017 I call myself looking for this info on google but no luck. My question is are the cylinder base studs relocated to fit the dm cylinders on stock cases. I know other extensive work has to be done which is more than I can do. But Reason I ask is I have a set of cases with one stud broken off in the case. If they are relocated to fit the dm style cylinders then I won't worry as much about getting it out without damaging the case but if they stay in same position then I need to be very careful when extracting the broken stud. Quote Link to comment Share on other sites More sharing options...
JTmachining Posted February 15, 2017 Report Share Posted February 15, 2017 1 Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 15, 2017 Report Share Posted February 15, 2017 If you are going to do a DM in stock cases I would HIGHLY suggest starting with a BRAND NEW set of cases. it is too expensive to set them up to be messing with a nasty old set that has been hot/cold 5000 times, flexed, whacked, beat, etc..... Buy new! Quote Link to comment Share on other sites More sharing options...
penguin Posted February 15, 2017 Author Report Share Posted February 15, 2017 I can see where that should be considered. But that didn't answer the question. Are the studs relocated or do they stay in same position. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 16, 2017 Report Share Posted February 16, 2017 I can see where that should be considered. But that didn't answer the question. Are the studs relocated or do they stay in same position.All the same location except the ones that are not. Quote Link to comment Share on other sites More sharing options...
stpltn Posted February 16, 2017 Report Share Posted February 16, 2017 Per CP website Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
registered user Posted March 5, 2017 Report Share Posted March 5, 2017 is it just me or does these transfer look very asymmetric from one side to the other ? Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 5, 2017 Report Share Posted March 5, 2017 is it just me or does these transfer look very asymmetric from one side to the other ? "Inside transfers " ? Yeah they look a little uneven don't they lol. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
JTmachining Posted March 5, 2017 Report Share Posted March 5, 2017 is it just me or does these transfer look very asymmetric from one side to the other ? RU build 2020 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 5, 2017 Report Share Posted March 5, 2017 Casting shift. Quote Link to comment Share on other sites More sharing options...
registered user Posted March 5, 2017 Report Share Posted March 5, 2017 "Inside transfers " ? Yeah they look a little uneven don't they lol. Sent from my SM-S820L using Tapatalk no the inboard 6 trans look all sqaushed up more than the outer 6 Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 5, 2017 Report Share Posted March 5, 2017 this is what l thought you meant, but I'm picking up what you're putting down now. Sent from my SM-S820L using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted March 5, 2017 Report Share Posted March 5, 2017 no the inboard 6 trans look all sqaushed up more than the outer 6With a 102 spread there is limited space there. Those are a 78 bore. Now think about a DMX that is 80 83 or even 85 bore. Now you will analyze this to death, but the 85 bore DMX's have proven to be superior in performance than its 120 spread Cougar cyld big brother. Quote Link to comment Share on other sites More sharing options...
JTmachining Posted March 5, 2017 Report Share Posted March 5, 2017 With a 102 spread there is limited space there.Rocket scientist Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted March 5, 2017 Report Share Posted March 5, 2017 ^^Gay. 1 Quote Link to comment Share on other sites More sharing options...
