Ibezy Posted February 2, 2017 Report Share Posted February 2, 2017 (edited) Hey everyone! I have a 99 shee with: fmf gold series exhaust pro design cool head and intake manifold (not sure what else to call it) vforce reeds stock bore uni filter tors and parking brake delete jetted to 280 mains and 25 pilots My problem is that it bogs through the full throttle (idle up to full throttle). I've tried 310 and 320 jets in case it wasn't getting enough fuel and have tuned the air mixture from all the way in to 6 turns out. There is no difference no matter what I do. The carbs have been rebuilt & synced, floats adjusted to 21mm, stator and coil tested and within range, no air leaks, tors and parking sensors have been cut out of the harness. The motor only has a few hours on it after just having redone the top end; I have not done a leak down test yet or compression test, but the compression seems fine.I'm not sure what else to try at this point. Any ideas? Edited February 2, 2017 by Ibezy Quote Link to comment Share on other sites More sharing options...
RIPPIN' IT UP Posted February 2, 2017 Report Share Posted February 2, 2017 Check carby slides aren't in the wrong way. Sent from my ZTE T84 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ibezy Posted February 2, 2017 Author Report Share Posted February 2, 2017 Check carby slides aren't in the wrong way. Sent from my ZTE T84 using Tapatalk I have checked that, they are in correctly. Quote Link to comment Share on other sites More sharing options...
RIPPIN' IT UP Posted February 2, 2017 Report Share Posted February 2, 2017 Choke tube & carby bowls all correct? Sent from my ZTE T84 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ibezy Posted February 2, 2017 Author Report Share Posted February 2, 2017 Choke tube & carby bowls all correct? Sent from my ZTE T84 using Tapatalk Yup, those are also in correctly. I double checked on that. Quote Link to comment Share on other sites More sharing options...
RIPPIN' IT UP Posted February 2, 2017 Report Share Posted February 2, 2017 Ok so was running fine then started doing this? Sent from my ZTE T84 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ibezy Posted February 2, 2017 Author Report Share Posted February 2, 2017 Ok so was running fine then started doing this? Sent from my ZTE T84 using Tapatalk It was running fine after the rebuild a few months ago, then the trans went out; I rebuilt it once more and it rode fine, this was about a month ago. About a week ago I wanted to take it out, but it kept bogging and wont ride right, so I rebuilt the carbs and this has been happening ever since. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 2, 2017 Report Share Posted February 2, 2017 What's the last thing you messed with or changed since it ran right? Seen your last post Check the pipes for a nest. Quote Link to comment Share on other sites More sharing options...
Ibezy Posted February 2, 2017 Author Report Share Posted February 2, 2017 (edited) What's the last thing you messed with or changed since it ran right? Seen your last post Check the pipes for a nest. Since it last ran right, I haven't done anything up until a week ago. A week ago when I went to ride it, it kept bogging and I found the the idle screw had fallen out some how. I put in a new idle screw and it still didn't run right, so I rebuilt the carbs. Pipes are clean. Edited February 2, 2017 by Ibezy Quote Link to comment Share on other sites More sharing options...
Ibezy Posted February 2, 2017 Author Report Share Posted February 2, 2017 another point, it's been smoking out the exhaust a little more than it used to. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 2, 2017 Report Share Posted February 2, 2017 You've checked the pipes since it sat for 3 weeks? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 2, 2017 Report Share Posted February 2, 2017 So it ran fine, put away, 3 weeks later pulled out and only bogs? No work done - nothing changed? Quote Link to comment Share on other sites More sharing options...
Ibezy Posted February 2, 2017 Author Report Share Posted February 2, 2017 You've checked the pipes since it sat for 3 weeks? I checked the pipes two days ago, I just wanted to go through everything to narrow down the possible problems. Quote Link to comment Share on other sites More sharing options...
Ibezy Posted February 2, 2017 Author Report Share Posted February 2, 2017 So it ran fine, put away, 3 weeks later pulled out and only bogs? No work done - nothing changed? Correct, I'm assuming when I went to take it for a ride, the idle screw fell out. No work has been done prior to the screw falling out. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 2, 2017 Report Share Posted February 2, 2017 I've seen them super flooded and take forever to clean out Quote Link to comment Share on other sites More sharing options...
