Craig B Posted February 20, 2017 Author Report Share Posted February 20, 2017 Just wanted to update this. Picked up another frame from Sheerider11 [ thanks Rob]. I also bought another set of drag a-arms from Turbo chassis. I tried the Tyson drag arms on both frames and could not get good camber alignment. Thur. the arms showed up from Turbo chassis and I got on it after diner. Turns out the original frame was bent and the Tyson arms are off. The new frame and Turbo arms are straight and alignment was no issue. The shitty part was I had to start all over cutting all unwanted tubes off the frame and grinding all of it down. So far this is how it sits after the weekend. I will need to do something with the foot pegs because I am just to tall for this chassis. Not sure if I should just lower them or go forward too. 1 Quote Link to comment Share on other sites More sharing options...
special06shee Posted February 20, 2017 Report Share Posted February 20, 2017 Asphalt bikes look so badass! Quote Link to comment Share on other sites More sharing options...
JTmachining Posted February 20, 2017 Report Share Posted February 20, 2017 Track or street racing? Quote Link to comment Share on other sites More sharing options...
Craig B Posted February 20, 2017 Author Report Share Posted February 20, 2017 Track or street racing? probably both Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 1, 2017 Author Report Share Posted March 1, 2017 Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted March 1, 2017 Report Share Posted March 1, 2017 That thing looks killer! Sent from my SM-S820L using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
JTmachining Posted March 1, 2017 Report Share Posted March 1, 2017 Did u use 4WA front mtr mounts? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 1, 2017 Report Share Posted March 1, 2017 Looks sweet. I'm curious though, how's it going to handle off the jumps and through the whoops? Doesn't seem like much suspension travel. Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 1, 2017 Author Report Share Posted March 1, 2017 Did u use 4WA front mtr mounts? Yup! Got them from Clint. Was good to deal with. Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 1, 2017 Author Report Share Posted March 1, 2017 Looks sweet. I'm curious though, how's it going to handle off the jumps and through the whoops? Doesn't seem like much suspension travel. It has air struts. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted March 2, 2017 Report Share Posted March 2, 2017 (edited) Man I couldnt imagine going 90+ mph with those skinny tires on the front, would play mind games with me. Looks good though Edited March 2, 2017 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
penguin Posted March 5, 2017 Report Share Posted March 5, 2017 Did you make those front motor mounts or buy them. Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 6, 2017 Author Report Share Posted March 6, 2017 Did you make those front motor mounts or buy them. I bought them from 4 Wheel addiction. Quote Link to comment Share on other sites More sharing options...
penguin Posted March 6, 2017 Report Share Posted March 6, 2017 Ok I will check them out. Very nice build you fit going. I will be following it. Thanks for the info. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 6, 2017 Author Report Share Posted March 6, 2017 A Little update. Got the cylinder back from Sleeper today. Made some Alu. pegs and a mount for the OOF pipes. Hooked up some rad hoses. Waiting on a chain and thumb throttle. 1 Quote Link to comment Share on other sites More sharing options...
