jeremiahnelson15 Posted January 23, 2017 Report Posted January 23, 2017 How beneficial is it to get the different slides for the PWK carbs? I have a 2002 banshee with stock internals, PC pipes, cool head, PWK 35 mm carbs, no porting that I know of, running 6 inch pods, dynatek ignition, and vforce 3 reeds. I believe the carbs are too big for this setup, after doing some research I found a site that you can buy different slides for these carbs from. Has anyone tried these to lean it out, or will I be better off going down to smaller carbs? Quote
Mr.banshee Posted January 23, 2017 Report Posted January 23, 2017 Have you check your cylinders? If they are not ported smaller carbs.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk Quote
Tedder Posted January 23, 2017 Report Posted January 23, 2017 http://www.sudco.com/images/PWK.gif Quote
jeremiahnelson15 Posted January 23, 2017 Author Report Posted January 23, 2017 https://jetsrus.com/carburetor/carb_keihin_PWK33-41_carb_exploded_view_parts.html Quote
special06shee Posted January 23, 2017 Report Posted January 23, 2017 I did not have any luck running pwk35s on stock motors. What i mean is, under wot the 35s would run well and you could definitely feel them pull better then stock carbs on the big end but i never could get them to perform as smoothly as stock carbs for a "trail" application. I tried every jetting combo and needle combo but i never could get rid of the bottom end/midrange hiccups. I too was looking into different slides but aborted mission and just slapped the stock carbs back on which is what id recommend to you. Stock carbs actually work very well. I ran them on mtrs making mid 70s hp. 1 Quote
jeremiahnelson15 Posted January 24, 2017 Author Report Posted January 24, 2017 I'll have to try to find some stockers in the shop then if all else fails, I will bite the bullet and buy some stock carbs or some 28 mm carbs. Quote
jeremiahnelson15 Posted January 24, 2017 Author Report Posted January 24, 2017 what jets would be safe to put in the stockers, so i can do a plug chop? Quote
