AmericanBuilt Posted August 1, 2017 Author Report Share Posted August 1, 2017 No, the TORS completely kills spark.I'll be deleting both so I won't sweat it. Hell I might just part the bike if I can get myself to.Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted August 1, 2017 Report Share Posted August 1, 2017 ... Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 5, 2017 Author Report Share Posted August 5, 2017 What exactly is this whole for on top of the case?Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 5, 2017 Author Report Share Posted August 5, 2017 What exactly is this whole for on top of the case?Sent from my SAMSUNG-SM-G891A using TapatalkAnyone?Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 5, 2017 Report Share Posted August 5, 2017 Just a drain for crap don't collect on the case, goes clear through to the ground. One of two up there. Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 8, 2017 Author Report Share Posted August 8, 2017 Just got this bike back together, I took the motor out to clean off all the shit that was caked on it. I deleted tors and parking brake. Put pods on as well. Can't get the sucker to crank over. How do I diagnose This? It ran before I tore it apart so I did something somewhere but I'm not sure?Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
ginger Posted August 8, 2017 Report Share Posted August 8, 2017 did you remove the brains of the TORS system? IF so then it may need a bigger pilot due to the pods. but if you didnt, the TORS system is cutting out your spark. Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 8, 2017 Author Report Share Posted August 8, 2017 did you remove the brains of the TORS system? IF so then it may need a bigger pilot due to the pods. but if you didnt, the TORS system is cutting out your spark. I've unplugged and removed the sensor for the throttle housing and same with the deals on top of the carbs? Am I missing something?Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 8, 2017 Author Report Share Posted August 8, 2017 I've also pulled and unplugged the sensor out of the clutch lever.Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 8, 2017 Author Report Share Posted August 8, 2017 Alright I unplugged the brains I believe. Right next to the spark plug box? Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 8, 2017 Author Report Share Posted August 8, 2017 Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 8, 2017 Author Report Share Posted August 8, 2017 Should the bike at least start if jetting is off? Just wanna narrow it down a little more before I drive an hour to Rocky mountain. Compression is 125/130 Mods are T5, pods, boost bottle(I know there junk) and a cool head. Not sure on internal mods but if say none. Stock jetting I believe as I just put a new kit in them.Sent from my SAMSUNG-SM-G891A using TapatalkSent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
ginger Posted August 8, 2017 Report Share Posted August 8, 2017 if thats the case you probably need to rejet as pods allow a lot more air in then the airbox. Quote Link to comment Share on other sites More sharing options...
AmericanBuilt Posted August 8, 2017 Author Report Share Posted August 8, 2017 if thats the case you probably need to rejet as pods allow a lot more air in then the airbox. Just picked up 27.5 and 30 pilots. My needle is on the third slot. Do I need go sync carbs bow that I've redone them.Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
ginger Posted August 8, 2017 Report Share Posted August 8, 2017 i never hurts to re check to make sure they still car synced remember you want to have it where you need the choke on to get it to fire. Quote Link to comment Share on other sites More sharing options...
