Rookies first build.
Should I start from all the way in and back them out. I have one but it's at a family members house with my other build.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Yes all the way in..in enough until late the slides move..
Good those manuals are handy..
Sent from my SM-A310Y using Tapatalk
I'd pull ur carbs clean them check all your jets proper definitely up your mains..make sure your carbs are synced enough an can see both ping Mark's in the windows..adjust your idle screws an you should be good to go..choke it couple kicks with key off flick it on an your away m8
You should of left it to the professionals like me.
Did you leak down test the motor after you built it? If not stop trying to start it an leak down test it
Did not build this motor. The slides were high because my motion pro idle screw are ungodly long.
