Carbs
q8bizkit78
i just installed 4mm strocker crank and im useing the 35mm carbs im thinking of swiching back to stock carbs cuz im losing the low end so what do u guys think i wana pop wheeleeeeeeeeeeeeeeeeeeeeeeeeeees :huh:
YOu should be able to handle those carbs w/ a 4mm and dragporting.....try adjusting the carbs....try a smaller pilot or larger pilot, smaller pilot will start hard when cold, but easy when warm, a rich pilot will start easy when cold and hard when warm. A really rich pilot will make your shee act like the choke is out. You have to keep revving it to clean the motor out... adjust air screws to the best throttle response. Also try adjusting the needles a different height and find the best low end pull....If none of this works, then go down to a 28mm carb..
