My first Banshee - is this normal?
Baileycakes
I did a compression test. About 118 on both sides.
It's not bogged down when taking off..
There is never a point when in letting off the clutch where I can slowly roll.
It's either give gas and take off really quickly or if I don't give alot of gas it will stall.
Starts up with no issues. I had a jet kit and pipes installed recently but it was doing this before I installed the pipes...
I'm trying to make a video to post..
If a clutch needs replacing will it fail for all gears?? Or could my situation where only going in to first gear is a sign of bad clutch?
I know it's hard to diagnose a problem without seeing the bike, so I want to say thank you to all! I appreciate your input.
Buy a clymers manual, and tools.....your going to need it sooner, or later. 32:1 is a good ratio...it's preference though. Ask 100 ppl, and get 75 different answers. To answer your question yes that's rich af.
Sent from my SM-S820L using Tapatalk
