Wiring lights
Two of those wires (from banshee) will be positive, with a test light you can tell which ones are. One for low beam one for high. I think grey is the ground... My '99 is wired the same way, and I have yellow and green both tapped into the power wire, and I have a black wire where you have a grey, which is grounded right to the light's ground. Either way, you can wire both of the positive wires to the red, and the negative to the black on the light.
