J-Madd Posted January 6, 2017 Report Share Posted January 6, 2017 [This is not a post to start any shit whatsoever, but just some things that come to mind] Is there a fan on during any of the dyno runs where pipes are compared? (In this thread or the one Ayesully referenced). Tyrelz mentioned that Snipers liked more fuel. Do they like a higher temperature? Up to a point, more fuel = higher pipe temperature (not to be confused with combustion chamber temp). Now if the motor is pumping out raw fuel like during clean out with alky, of course that will cool the pipe down. Sound waves move faster through a hot pipe. The faster they move, the faster the wave returns the mixture in the pipe back through the exhaust port. Faster sound waves = shorter tuned length and higher target rpm. Things that increase combustion chamber temp (timing, compression, moderately lean condition) decrease pipe temperature. Knowing some of this it's easier to see why a pipe may not perform as intended without knowing how much heat an engine will put into it. This would also make sense regarding stinger diameter and the heat of the pipe. Where do you put AFR probes in a 2 stroke? I don't know because I've never seen it done. I also don't know how it can be reliably done, and it's not just because of the oil. There is no place from piston to stinger where the gases are representative of what was burned in one cycle.??? Its always moving back and forth and takes several cycles to exit. I must be wrong because I've seen AFR mentioned here and on other dyno sheets but I don't see how. Very interested in others opinions/facts on this...and feel free to point out any errors in my rant. Move this to a new thread if you want. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 6, 2017 Report Share Posted January 6, 2017 I don't know anything about any of that. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted January 6, 2017 Author Report Share Posted January 6, 2017 (edited) Yes there was a fan on (brake on the dyno as well) the probe was put in 1 of the two silencers in the back. We would usually sniff both sides as well with the probe, not always though. Edited January 6, 2017 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
0sikshee Posted January 6, 2017 Report Share Posted January 6, 2017 Sully do you plan on selling the Slps? Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted January 6, 2017 Author Report Share Posted January 6, 2017 Sully do you plan on selling the Slps? Not sure yet. Probably not i wanna try them at the dunes this spring. If i do ill let you know though. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 6, 2017 Report Share Posted January 6, 2017 Not sure yet. Probably not i wanna try them at the dunes this spring. If i do ill let you know though.Silver lake ? Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 6, 2017 Report Share Posted January 6, 2017 Yes there was a fan on (brake on the dyno as well) the probe was put in 1 of the two silencers in the back. We would usually sniff both sides as well with the probe, not always though.Is it possible the fan cooled the pipes during the run? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 6, 2017 Report Share Posted January 6, 2017 Is it possible the fan cooled the pipes during the run? No. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted January 7, 2017 Author Report Share Posted January 7, 2017 Silver lake ? Sent from my SM-G900V using Tapatalk Yes sir!J madd its a small fan i doubt it. Plus we used it on every pipe we tested. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 7, 2017 Report Share Posted January 7, 2017 Yes sir! J madd its a small fan i doubt it. Plus we used it on every pipe we tested. Good. We'll just throw that theory away then. I've wondered if it even matters, but Menz always shut the fan off during the dyno pulls. I didn't know why at the time. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 7, 2017 Report Share Posted January 7, 2017 Yes sir! J madd its a small fan i doubt it. Plus we used it on every pipe we tested. I've never been there. Put I do plan on going this year. Shee probably won't be done but I'll have the kx450f Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 7, 2017 Report Share Posted January 7, 2017 I've never been there. Put I do plan on going this year. Shee probably won't be done but I'll have the kx450f Sent from my SM-G900V using Tapatalk Get that bitch done! Let's see those LEDs! Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 7, 2017 Report Share Posted January 7, 2017 (edited) Get that bitch done! Let's see those LEDs!I know man I know. Ball is not in my court right now so my hands are tied. Sent from my SM-G900V using Tapatalk Edited January 7, 2017 by controls77 Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted January 7, 2017 Report Share Posted January 7, 2017 Built the motor 2 years ago and Cam suggested sb Shearers so that is what I bought. Just doing a frame swap and my shears are a little worn so I thought of getting a new set is all. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted January 7, 2017 Report Share Posted January 7, 2017 Built the motor 2 years ago and Cam suggested sb Shearers so that is what I bought. Just doing a frame swap and my shears are a little worn so I thought of getting a new set is all.Cub or serval Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
