Ideal Cooling System?
Looking for opinions on the "perfect" cooling system for my bike. After 2 weeks of researching I can't seem to make up my mind. Looking for field tested feedback. Thanks
(example: Toomey rad, engine ice, Pro Design Impeller, Cool Head etc)
Make sure your carburetors are tuned properly and the engine is free of air leaks. Both of those things can cause issues with high engine temperatures. Fuel, oil premix, pipes, dome specs, air filter maintenance, and clutch condition can also play a factor when excessive engine temps are involved. If you've checked all those potential problematic factors. Move on to the paragraph below.
The increased coolant holding capacity combined with the improved and much more efficient water jacket design that the CP Industrie's Serval and PV Cheetah Mono-Cylinders and the Driveline Assassin Cylinders make a HUGE difference in the engines average operating temperatures. Changing the stock jugs out for a set of aftermarket cylinders produces the greatest reduction in engine temperatures.
I also would recommend that you purchase the following cooling upgrades, components, and products:
• Chariot or Noss Cool Head
• GPI Oversized Aluminum Radiator
• GPI Silicone Hoses
• CV-4 High Pressure Radiator Cap
• Mull Engineering or Chariot Billet Impeller
• Chariot Quick Drain Water Pump Cover
• TWO2COOL Racing Coolant/Antifreeze
• Royal Purple "Purple Ice" Coolant Additive
• TWO2COOL RTL-2 Crankcase Oil
• 4oz of ZMAX Micro-Lubricant In Crankcase
• Keep OEM Coolant Overflow Reservoir
I've found all the stuff I listed above to be beneficial to the Banshee's Cooling System. I used to run hare scrambles so I came up with a few other mods that will reduce engine temperatures. I purchased a 1990 OEM Suzuki LT250 Radiator Air Scoop and modified it so it would fit and channel fresh air through the radiator while traveling at very low speeds. Another good way to get temperature reduction is increase your crankcase oil holding capacity. This is done by purchasing a Lock-Up Clutch Cover and modifying the rear crankcase vent and replacing the rear fitting and check valve with a bigger aftermarket version. I hope my input is beneficial to you and helps you out.
I get that, but i think the main reason people buy coolhead is for changing dome, since cooling is not realy an issue, but i may be wrong, my experience with shee engine is pretty short.
uh, I may be wrong but the cool heads have more coolant capacity too
Edited by Ayesully810
