tonyd278 Posted January 1, 2017 Report Share Posted January 1, 2017 Trying to remove the clutch basket so that I can get into the engine to remove a welded push rod but have hit a problem. I cannot remove the small nut attached to the screw and cannot simply pull them out because I think that might be welded. What can I do to remove this? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 1, 2017 Report Share Posted January 1, 2017 Trying to remove the clutch basket so that I can get into the engine to remove a welded push rod but have hit a problem. I cannot remove the small nut attached to the screw and cannot simply pull them out because I think that might be welded. What can I do to remove this? Release the clutch cable, work the lever to see if the rod indeed will move. Use a magnetic Ben to try and retrieve it from the bore. If it won't come, you will have to split the cases. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted January 2, 2017 Report Share Posted January 2, 2017 You can also tip the bike over to aid in what trick said. If that doesn't work, split the cases. While in there replace all seals, gaskets etc. Quote Link to comment Share on other sites More sharing options...
tonyd278 Posted January 2, 2017 Author Report Share Posted January 2, 2017 Thanks for the tips...I have already removed the engine from the bike...it appears that the ball welded to the screw inside the push rod behind the pressure plate and to the actuator... Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted January 2, 2017 Report Share Posted January 2, 2017 Parts are pretty cheap, buy new pieces. Try n post pics . Did you try n impact gun to break it free 1 Quote Link to comment Share on other sites More sharing options...
salmon_slayer06 Posted January 13, 2017 Report Share Posted January 13, 2017 What causes this to happen? Just wondering. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 13, 2017 Report Share Posted January 13, 2017 Holding the clutch in while the bike is in gear and in motion. Especially on deceleration or down hill. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted January 13, 2017 Report Share Posted January 13, 2017 Friction welding is some sick shit Quote Link to comment Share on other sites More sharing options...
