Clutch
The Don
Any help
You can tear into it and replace the clutch pretty easily. Getting a Clymers manual will be worth your while as well.
If you want someone to walk you through changing the clutch, someone may chime in. Probably need to know your baseline mechanical skills and knowledge of these machines.
Welcome to BHQ
Went to the bar also has no tension lol
If pulling in the lever and it has no tension but did before check your pancake bearing. My buddy's clutch did the same thing. Was fine then during the middle of riding had no tension when he pulled in the clutch lever at one point. Turned out to be the pancake bearing broke. Like stated above get a cylmers manual if your not sure what your doing.
