I am hoping I can get a little help in changing over my carbs from gas to alky.  I know that I need to drill the main jet and dump tube to about .117, I ride at St. Anthony's in Idaho and it is about 4300' above see level.  I need help knowing what needle I should run and what pilot jet jet I should start with.  I have power jets also.
Thanks for any help you all can give,
Eric
I forgot to mention, this will be for a 4mm stoke cylinder 385.
