Derpy Drifter Posted November 25, 2016 Author Report Share Posted November 25, 2016 Alright, thank you, that is making more sense to me. I will go do that real quick. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted November 25, 2016 Report Share Posted November 25, 2016 After finding pilot size I would def throw a bigger main in there considering time of year. If using the stock needle I've found going all the way to the richest setting has been the sweet spot on many engines with those pipes. I like to use the toomey needle as they offer more adjustability . If the motor sounds hollow it's lean Quote Link to comment Share on other sites More sharing options...
Derpy Drifter Posted November 25, 2016 Author Report Share Posted November 25, 2016 I've got the carb off and apart here and I'm not sure what exactly you're talking about. I went ahead and took a few pictures in hope that they will help, but I don't know how to post them in the thread here. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 25, 2016 Report Share Posted November 25, 2016 Ok, posting photos here requires a photo host. Tapatalk is the easiest way. Are you on a apart phone or tablet? If so down load the tapatalk app. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted November 25, 2016 Report Share Posted November 25, 2016 I've got the carb off and apart here and I'm not sure what exactly you're talking about. I went ahead and took a few pictures in hope that they will help, but I don't know how to post them in the thread here.there is s small hole in front of the main jet. Did you have the little plastic slash guard in there? Looks like a white umbrella thing. The front of that clips into where the pilot jet is Quote Link to comment Share on other sites More sharing options...
Derpy Drifter Posted November 25, 2016 Author Report Share Posted November 25, 2016 I'm on my PC actually Quote Link to comment Share on other sites More sharing options...
Derpy Drifter Posted November 25, 2016 Author Report Share Posted November 25, 2016 there is s small hole in front of the main jet. Did you have the little plastic slash guard in there? Looks like a white umbrella thing. The front of that clips into where the pilot jet is Yes and I took that little thing off. Is the pilot jet the little tiny thing waaay down in that hole? Quote Link to comment Share on other sites More sharing options...
TrickedCarbine01 Posted November 25, 2016 Report Share Posted November 25, 2016 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 25, 2016 Report Share Posted November 25, 2016 Yes and I took that little thing off. Is the pilot jet the little tiny thing waaay down in that hole?yup Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 25, 2016 Report Share Posted November 25, 2016 Make sure to use a properly sized screw driver so it doesn't Gaul the top up. If it doesn't wanna come right away, use a hammer to give the end of the screw driver a little whack. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted November 25, 2016 Report Share Posted November 25, 2016 Yes and I took that little thing off. Is the pilot jet the little tiny thing waaay down in that hole?Yeah, a small flat head screw driver.Make sure you get a good "bite" on it. The brass can strip kind of easy Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
Derpy Drifter Posted November 25, 2016 Author Report Share Posted November 25, 2016 (edited) It says 2.5 or 25. not sure if there's a dot Edited November 25, 2016 by Derpy Drifter Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted November 25, 2016 Report Share Posted November 25, 2016 It says 2.5You mean 25? Or 27.5? Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 25, 2016 Report Share Posted November 25, 2016 It says 2.5 or 25. not sure if there's a dotThat's stock as fuck. You definitely need at least a 27.5 pilot. Any local shops you can buy jets? I'd say you should grab 27.5 pilots, 280 & 290 main jets. Quote Link to comment Share on other sites More sharing options...
Derpy Drifter Posted November 25, 2016 Author Report Share Posted November 25, 2016 You mean 25? Or 27.5? Sent from my SAMSUNG-SM-G890A using Tapatalk It's 25 my apologies. There was a little smudge or something that looked like a point Quote Link to comment Share on other sites More sharing options...
