Having trouble dialing in my 35mm air strikers at idle. My bike is ported, open air filter and cpi inframes with stock ignition. Carbs are jetted with 35 pilots 2.5 turns out and 152 mains. I am at sea level and the bike still has the tendency to load up at idle. Bike runs fine on the big end but no luck at idle and pilot jets smaller than 35 are not offered to the best of my knowledge. Any suggestions are insite on this matter will be greatly apprecitated.
Thanks for the suggestion. How much will having my slides cut to a #6 affect the needle and main jetting? Also, do you think there is any good reason for this extremely rich condition? Could the port work be that efficient?
It's rich down low because strikers come with like #3 slides. Regular PWKs come with a #6. The slide effects idle to 1/8 throttle mostly and less effect up to around 1/2.
Leaning the slide cutout will make the carbs tune similar to regular pwks.
You could always try raising the slides a smidge to see if it helps.
Years ago we ran 35mm Air Strikers on a 358 cub asphalt bike with the OEM slides and needles.
At 1200ft with oxygenated VP CMP
Mains were 162 in the heat of the summer and 165 when it cooled in the fall
Pilots 42
