1st build help please
bradyray
I bought a 95 basket case the other day. I've had 2 banshees before but only did minor work to them. This one is completely taken apart. It came with everything to put the body back together. Motor wise it came with 1 complete bottom end, another bottom end missing crank, 2 sets of jugs (one set I believe has been big bore sleeved) stock set mic'ed at 65.7ish. My question is can I run a stock stroke crank with the big bore cylinders? The one bottom end that has a crank I believe is a stock stoke. It has 29L stamped on the rods. Thanks guys.
Pardon my ignorance but by welded pins are you meaning the lower rod pins? And I have absolutely zero information on any of the parts. Guy I got it off of bought it as is and he didn't know what he was doing so I got it for a steal.
Edited by bradyray
From what I've read the 29L rods are stock rods. And the pins are not welded. I think I'm going to put new bearings on the stock crank and throw it back in its case. Have the stock cylinders cleaned up/bored if necessary and ride that engine while I build the 2nd motor. I'll have to get with someone to tell me if the big bore jugs are stock port or not. Thanks.
  • Like 1
